Michael's never ending prject.
Re: Michael's never ending prject.
15x7 stockers T. But I believe the calipers will be changing based on what I discussed with him.
Love this build and want to see more!
- crashdean
- Bronco Info: Sleeper 1993 White OJ looking Bronco
Thanks ChaseTruck754 for the wheels. I had the rotors mounted backward which pushed everything out 1". Once I switch them, it brought the caliper and rotor to where they needed to be. Should have looked at the pictures on John website before installing. The Alcoas will fit fine once the centers are opened up for large hubs.
drj777
- Bronco Info: 1986 5.0 XLT - bone stock w/ 4.56s
....drool....
drj
drj
- exMDR volunteer / SCORE class 1 chaser / KOH #10 chaser -
-'86 FSB 5.0 XLT (4.56s / FL headers)
-'03 f150 S'crew 4x4 (4.56s / Detroit / Deavers)
- crashdean
I got the resevoir hoses shortend on the 3.0 coilovers and the spings installed. I had Mirage in Santee do it for me. They are a great help and are really reliable. Installed the shocks and made mounts for the resevoirs. I got everything painted and torqued. Autofab is also making me equal length steering.
- DSC01050c.jpg (289.42 KiB) Viewed 2469 times
- DSC01049c.jpg (293.15 KiB) Viewed 2469 times
- DSC01047c.jpg (265.33 KiB) Viewed 2469 times
- poolman
- Bronco Info: 84 Bronco,Body off reconstruction. Auto Fab suspension,mix of 84-96 parts.
Nice work!
94 Bronco roller for parts
91 F150 4x4for parts
96 Bronco for parts
84 Bronco for 351W
96 Bronco for parts
84 Bronco for 351W
- crashdean
Thanks Steve. I've got until November to get her on the road. We are expecting a baby girl in December so its finish it or find a reason to sell it. I choose to finish it.
Good choice! And congrats on the baby.
Now get this thing done! I can't wait to see it rolling!
Congrats! Keep up the good work!crashdean wrote:We are expecting a baby girl in December....
- crashdean
Seeing how these Autofab fenders are going to look. I put jack stands under the front i beams to check the sag of the front end. It didn't sag enough....
So I pulled the shock and having the upper spring change from 400# to 300#.
This should set the front end were I need it. Also taking the front spindles to Autofab to have them modified for the equal lenth steering setup.
- Vessel fenders from Autofab.
- DSC01092a.jpg (74.79 KiB) Viewed 2381 times
- DSC01087a.jpg (103.39 KiB) Viewed 2381 times
- cwrisley
Bronco is looking good, man. I gotta cruise down and sniff around a bit.
@cwriz
- crashdean
Wait until next Thursday. I took all the shocks and brakes off the front so it looks like it did last time you saw it. I will have everything back on then. Are you going to keep the Bronco or give up on that dream?
- cwrisley
Bronco is staying. I just need to pick one project and stick with it. I want to get the 77 driving before I dive head first into the Bronco.
@cwriz
- cwrisley
I saw a Bronco last night sitting on its own weight with new AutoFab glass.......just sayin'!
@cwriz
- crashdean
Bought a radiator from Autozone for $145 and installed it. Went down and had 4 BFG All Terrains installed at Discount Tire. Need to get the fenders installed next time I work on it. Looks like the rear of the Bronco is going to sit just below the front without lifting it. I plan on getting the rear done later but with the baby on the way in Dec I just need to drive it and work as needed.
- DSC01211a.jpg (64.57 KiB) Viewed 2257 times
- DSC01206a.jpg (76.11 KiB) Viewed 2257 times
- DSC01198a.jpg (73 KiB) Viewed 2257 times
- DSC01197a.jpg (67.44 KiB) Viewed 2257 times
Good looking bronco..
So jealousnof the engine cage
- crashdean
So the Bronco is gone. Took everything off the Bronco and off to the salvage yard it went. Gave the engine and front clip to Chris along with the tailgate and hood. I did buy a 1993 white OJ Bronco to replace the 91. It has a clean body and 5.8 engine. It has no power windows or door locks. The stock A/C works really good though. First job is to get the E4OD out of there and get the C6 in. I will post it when the old stuff is out. Should get it done in a day since I already have the custom cross member done from the 91. Just have to find a day to do it. More to come. Will post pictures of the stock 93 soon.
crashdean wrote:So the Bronco is gone. Took everything off the Bronco and off to the salvage yard it went. Gave the engine and front clip to Chris along with the tailgate and hood. I did buy a 1993 white OJ Bronco to replace the 91. It has a clean body and 5.8 engine. It has no power windows or door locks. The stock A/C works really good though. First job is to get the E4OD out of there and get the C6 in. I will post it when the old stuff is out. Should get it done in a day since I already have the custom cross member done from the 91. Just have to find a day to do it. More to come. Will post pictures of the stock 93 soon.
Whoa!
Get to work already! I want to see this thing rolling!!!!
