- ImageUploadedByTapatalk1385356639.097409.jpg (198.66 KiB) Viewed 2047 times
Brian's '96
Re: Brian's '96
YETI
Re: Brian's '96
Hey Brian-- do you have any pics of what you did with your exhaust? If its in the 68 pages I tried to see it but might have missed it.
Thx
Thx
Re: Brian's '96
This is about the only picture I've got...
Re: Brian's '96
So thats just a 40 series then about 18" with a 90* dumping to the ground? Simple and sweet
Thanks!
Re: Brian's '96
Yup. Gives it a nice sound. Not too loud. Minimal droning inside the cab.
Re: Brian's '96
One more dumb question-- driving with the back window down-- is it carbon monoxide-ville or is it all good?
Re: Brian's '96
Don't do it.VintageIronFab wrote:One more dumb question-- driving with the back window down-- is it carbon monoxide-ville or is it all good?
Re: Brian's '96
Brian,
Hey The bracket you have that mounts the air cleaner (the version on the fenderwell) -what is the round part that filter mounts to? Also in the air box I thought the air intake temp sensor goes in that box (I think anyway) where/what did you do that with sensor-- leave it in free air or possibly tap the MAF sensor housing??
Re: Brian's '96
The round filter adapter was provided with the original K&N FIPK kit I bought in 2000. The inlet air temperature sensor is supposed to be directly in the airstream for optimum performance. I have it located a couple inches away from the filter, so there may be a slight discrepancy in temps, but not much.VintageIronFab wrote:Brian,
Re: Brian's '96
Here's my first attempt at GoPro footage of the suspension. Filmed at Pismo. There is no edit to the footage, so skip to 1:30 or so to get past the still shot. There are 3 small jumps in the last 5 minutes.
Re: Brian's '96
What's flopping around in front of the body mount?
Re: Brian's '96
You got passed by your own shadow at 9:54. What's up, you getting old?
Re: Brian's '96
HID stuff. Bulbs were problematic, so I threw the OE ones back in.Nick wrote:What's flopping around in front of the body mount?
Re: Brian's '96
Sweetness
Re: Brian's '96
Broke the large upper steering shaft bearing at KOH and just got around to fixing it. Wasn't too bad. Took a while for the first time though. Also, replaced the airbag with a fancy horn button.
Re: Brian's '96
Your truck is fast even when it's stopped!!!
Re: Brian's '96
cool wheel!
- 93Broncobuff
Re: Brian's '96
tcm glx wrote:Your truck is fast even when it's stopped!!!
Hahahah i see what you did there! Lol
- cypher
Re: Brian's '96
Can you please give the steering wheel dimensions? Size? Dish?
Re: Brian's '96
350mm diameter - 63mm dish. The Momo adapter puts this wheel about 1 1/8" closer to the driver than the factory wheel, which is what I was after for better control. Leg room is an added bonus.
