Hello All,
I am needing a set of factory single or double shock coil buckets-- I kind of want a pair of doubles for the look that I am wanting to go with. If you have a set collecting dust I am in need. PM me direct if you dont mind so I get the message faster.
Thanks,
Matt
Coil Buckets Wanted
Re: Coil Buckets Wanted
anyone fellas??
- Bronco Broker
I just throw a set away. But may have a set in a month of the dual shock set up. Also have a set of Camburgs for sale.
PM me if you are interested.
I've got a set of doubles.
- jhouse
- Bronco Info: long travel bronco bro 35 and coil overs
I have some I cut the out to put coils overs on and the set I had before cutting them of I had a lift spring with 2of the 2.0 with resi on it
Whiterhino1
- Bronco Info: 1994 bronco 4 inch lift 35's
I'm interested in those camburg buckets if u still have them
