Josh aka greaslifes 86
Re: Josh aka greaslifes 86
Oh cool gotcha. Ya I bent up 2 different bows similar to yours n I was having a hell of a time for head room due to height of the factory rear seat, so after I wAisted 40ft I said I gotta rethink this.. Just didn't want u throwing money away like me.
greaslife
Post by greaslife »
Little up date got the front end all back together and filled the diff. Would you know I got a leak at the driver side seal. So I get too pull it all down agin an
greaslife
Post by greaslife »
Here's a teaser pic.
Kel Fab Creations
Bronco Info: 95 Bronco
Post by Kel Fab Creations »
That SUCKS! I bought all new seals for the front end on mine while I had it apart for that very reason.
greaslife
Post by greaslife »
Thing is Kel my lazy ass just didn't put them in they are sitting on the bench
Kel Fab Creations
Oh man! That's makes it hurt even more. Lol.
greaslife
Post by greaslife »
Since I couldn't find a seal locally this weakened my A.D.D took over and got me here
Plan on doing cross bars between the b&c pillars along with a l from the b pillar too the b pillar brace behind the seats. I m thinking of a bar from the b&c pillar cross intersection for the rear seat shoulder harnesses then a seat frame too the b pillar. As soon as I get a chance I will show what Im Talking about.
Any suggestions ?
Nice progress!
greaslife
Post by greaslife »
Thanks. Here's what I was thing for the rear seats.
Any feed back would be grate I don't want too do this agin
greaslife
Post by greaslife »
The yellow circle ? I don't know if I should bend this pice or use straight tube too another floor plate and attach it to my rear shock mount
Cage is looking great Josh..... Not sure what you mean about the yellow circle
Use a floor plate, and do another down bar to intersect the kicker tube from the back rear corner at the same intersection as the rear seat crossbar, just my .02 cents though.
Looking good Josh.
I agree with Robert on the floor plate for the yellow circle. If you can take it through the floor to the frame there too. There's a body mount close by under that silver plate in the floor. Could be a good place to tie in.
And one more thought/idea is for the B pillar tubes - ones you have drawn in blue behind the pass seat. I'd go from the curve/bend in that one up at an angle to the upper bend where it hits both the horizontal and diagonal down bars to the C pillar area.
I can draw this for you if what I wrote above doesn't make sense.
This won't add a ton of weight or a tube that will really be in the way any more than what you have drawn, but it will add some support for that B pillar corner in a hard roll.
Excellent work man!!!
Polarcub
Post by Polarcub »
You have been busy josh! Glad to see your making progress.
greaslife
Post by greaslife »
Here she is on all four.
Quite beastly
I'd move outta the way!!!! Looks manly!
:o :o :o :shock: :shock: :shock: EEEPPPPIIICCCC!!!!!!!!!!!!
greaslife
Post by greaslife »
Here's the back all tacked up. I'm stoping here for now. That way I can come through the floor I will decide on that after my trip in two weeks
