Philo's 93 Bronco aka "Lucky Bronco #3"
Re: Philo's 93 Bronco aka "Lucky Bronco #3"
ChaseTruck754 wrote:Philo - box is 7"x8"x33" and weighs 6 lbs. You can use 92627 for my shipping zip if you need it.
It didn't dawn on me until I left the shop to think maybe I should try & just fit the beam ends in the box with this stuff. I think it's doable if you want. I can try tonight & see if they fit & get you a new weight if you'd want to do that.
Yea, just put it all together... It will get it out of your way sooner this way. Even heavy boxes from socal are only $12-14 to ship.
sounds good. I'll box um up tonight. Won't be back at a computer so I'll either text you the info or post up here when I get back tomorrow
Hey philo wanted to give u props for all the you tube footage, hard to find a bronco page without a vid of yours, nice work!
Rmc wrote:Hey philo wanted to give u props for all the you tube footage, hard to find a bronco page without a vid of yours, nice work!
Thanks!
Box is 8x8x33 and 29 lbs. now.
I will send a label to you tomorrow. Thanks!
The Bronco has a new calling in life... Roadrunner incubation machine.
Seabass
Bronco Info: 96 bronco
Post by Seabass »
haha awesome!
That is Bad ASS
Agui-E7TE
Post by Agui-E7TE »
That's gotta add some amount of power.. what's the conversion from birdpower to horsepower?
wayfastwhitie
Bronco Info: 1989 4in lift billie 5100
Post by wayfastwhitie »
Meep meep mo fuka! Haha
Agui-E7TE wrote:That's gotta add some amount of power.. what's the conversion from birdpower to horsepower?
Its a 3:1 ratio, Roadrunner To horse....
Started setting up to install 1" uniballs in my new beams. I ordered cups and Aurora uniballs from Nick Head at Kartek. The old misalign spacers that are on the truck now will work fine with these, and I also took inventory of what I had so I could order all the rest of the spacers, bolts, and heims for the front end and DDL.
Still gotta figure out a drain plug for the front diff that wont get destoryed by rocks and crap I run over.
You think you'll smash stuff to where you can't remove the existing drain plug?
Rmc wrote:You think you'll smash stuff to where you can't remove the existing drain plug?
More worried about smashing it to a point that it leaks. My other set of beams is beat in this area, even with the Autofab skid.
Oh I gotcha.
Any progress on the new rearend?
cs_drums wrote:Any progress on the new rearend?
I'll post some photos up later. Rotors are getting machined right now so the hubs are with the machinist.
300
Post by 300 »
What about drilling and tapping a plug in the cast housing itself? Only need a 1/8" or 1/4" threaded plug and it would be protected pretty well by the TTB arm. You will never get all of the oil out of there anyway but it is nice to get most of it.
Good idea.
