Need some help on the tranny I have
BigTex
Bronco Info: 1994 Bronco. Solo ms front beam kit, deavers in the rear with a full floater rear end.
Post by BigTex »
I am getting ready to order a deep pan for my 1994 5.0 bronco. I thought I had a E4OD but in JBG they have up to a 96 with a AODE. Can someone confirm what i have or tell me the difference. Maybe one has more pan bolts than another. By the way I have been doing a good amount work to this thing so it should be ready soon!!
big-d
Bronco Info: 1987 F150, 351W/418 Stroker, E4OD, F250 1356 W/fixed yokes, Sterling 10.25, D50 TTB 4" over
Re: Need some help on the tranny I have
Post by big-d »
If you go to the JBG site or any others that sell trans parts, you can look at the shape of the gasket for that trans or the amount of bolts it uses and compare it to yours. You can usually find it in the Chiltons or Haynes manuels too.
(Copied form JBG site as an example)
E4OD Pan Gasket 1989-Up
# 31198G
New
1989-96 Ford Bronco
1989-97 Ford F150, F250, F350
(20 bolt holes in pan)
Price: $4.00
Agui-E7TE
Post by Agui-E7TE »
This should help a bit. Just compare it to your trans oil pan and you'll be able to determine it.
MOSS2
Post by MOSS2 »
Deep pans dont have much return on investment besides looking neat. Another or larger cooler and temp guage would do more good for the trans life. Some brands use oddball filters other than stock so keep an eye out for that.
BigTex
Post by BigTex »
Thanks for the picture. That is what I needed. I feel the 3 extra quarts of fluid is a good thing. I already have a big cooler and my trans does not run too hot but the cooler the better. more fluid=cooler temps.
E4OD it is!!
78Class3
Post by 78Class3 »
Be careful, some of these extra capacity pans require a fair amount of fab work to the crossmember to be able to fit. Not sure about the E4OD but a 2 quart pan and a C-6 require this.
BigTex
Post by BigTex »
Just a quick update- Installed the Drahel deep E4OD pan. All I did was install the pan and replace the filter, a basic service and it took 17 qts to fill it up!!! the new pan is BIG. Around town the trans temp is 15 degrees cooler and it has been hot here. Overall I am very happy.
