Brian's '96
Re: Brian's '96
Finally finished up the burb and got started on the Bronco again. Opened up the holes in the pitman and swinger to .6250, then turned .027 off of the misalignment bushings for a nice snug fit. Progress will be slow as usual, but the Bronco has to be back online for a June family vacation, so...motivation!
- Silverslk
Re: Brian's '96
Looks good Brian!! Where is the vacation to? How's the burb?
Re: Brian's '96
We're going to June Lake again. Kids had a blast there the last time. Planning to spend a day at Bodie and take the tour this time. Fishin, ghost towns, campfires, smores, rc cars and good times! Can't wait. My oldest is graduating, so this won't happen much more with all of us.
Burb is doing great. The replacement spiders have fewer and bigger teeth, so they should hold up better. Trying some of that super duper Redline synthetic in it as well. It's got a 150k and hopefully it will go 250.
Re: Brian's '96
yikes wrote:Finally finished up the burb and got started on the Bronco again. Opened up the holes in the pitman and swinger to .6250, then turned .027 off of the misalignment bushings for a nice snug fit. Progress will be slow as usual, but the Bronco has to be back online for a June family vacation, so...motivation!
Looking forward to this B, attention to detail is great!
- economig
Brian's '96
X2!tcm glx wrote: Looking forward to this B, attention to detail is great!
- BajaF250
- Bronco Info: 1982 Ford F250
Re: Brian's '96
Very nicely done Brian... can't wait to see it complete!
Re: Brian's '96
I think I've got 4-4.5 hours in the machine shop so far. Shortened four of the bolts and milled flats on the bungs this evening. Knuckles are next.
Re: Brian's '96
looks good. I was just looking at the bungs I have for the crew tie rod the other night & figuring how to best secure them in the mill to do some flat spots in them.
Re: Brian's '96
What is the purpose of the flat spots?
Re: Brian's '96
Wrench flats for tightening the jam nuts.
- Silverslk
Re: Brian's '96
DAMN Brian!!!
Re: Brian's '96
Got the front end ready this morning. Taking the knuckles to the shop right now to bore the holes for the bolts.
Re: Brian's '96
What happened to the taper adapter?
- Silverslk
Re: Brian's '96
I'm pretty sure he is just keeping the adapters in the spares on the truck in case he ever has to replace a knuckle with a stock one to get home.philofab wrote:What happened to the taper adapter?
Re: Brian's '96
Not gonna lie...I'm a bit nervous about them. They look really nice, but I don't know the specific material type/quality used or what they're heat treated to. They'll be great back-ups for the tool bag. Decided to go double shear and if there's enough clearance, just going to run a 3/4" bolt with spacers to keep it simple. Overkill on size, but again, simple.philofab wrote:What happened to the taper adapter?
Re: Brian's '96
Have you seen the bungs that have a nut machined in to them?yikes wrote:Wrench flats for tightening the jam nuts.
Re: Brian's '96
Don't recall seeing any in a configuration that I liked. Knew I could trust the thread quality on the Kartek stuff.
- Becks_Bronco
Re: Brian's '96
This bronco gives me the warm and fuzzies.
