Re: BajaF250
Being upside down on the other side of the earth is making your brains mushy Rod.
You're thinking James with the raptor. I was talking Andy = SilverSLK or Slvrslk or however he spells it and Will = Becks_Bronco (now Heep).
Re: BajaF250
Whatever
- Becks_Bronco
Re: BajaF250
Gosh, i wish i had a Raptor! hahaha. That would make my life.AussieRod wrote:Well, he does have a Raptor, so we could excuse him a tiny bit (after he gets a Jethro Gibbs headslap)ChaseTruck754 wrote:As did Andy.
Will is the one that went backwards!
- BajaF250
- Bronco Info: 1982 Ford F250
Re: BajaF250
Hey Chris,lugobean wrote:Btw beautiful work on the spindles! And when you guys say keeping then warm, what is warm? Oven at 350 for an hour warm or get the torch out and keep them at a constant red?
First, thanks... second, the process I used to weld the cast material was to heavily tack the parts in place, then preheat the knuckles with an rosebud to about 500°F making sure it was evenly heated throughout the entire piece. You also have to ensure you are working in a draft free environment to avoid any differential cooling. I then completed welded the knuckle... the welding process kept the part in the 400°-450°F range. I then let the piece cool naturally which took about 4-hours. The results were pretty good... no cracks and good, clean welds.
- BajaF250
Re: BajaF250
Hey Ryan,RyanDS650X wrote:Everytime i check this build i just sit here, mouth open and shake my head.. WELL DONE, SIR! Hopefully you make it out to Barstow next weekend, i cant wait to see it in action.
Thanks... unfortunatly, it's not looking good for next weekend. It looks like I'm going to be out of town and will be unavailable.
- BajaF250
Re: BajaF250
AussieRod wrote:Whatever
Re: BajaF250
Not necessarily, A couple of the shops we use only do regular (type 2). For hard ano I would recommend Symcoat.BajaF250 wrote:So will any place that does anodizing do "hard anodizing?" Anyone know?
http://www.symcoat.net/
They may not be the cheapest, but they won't fuck up your parts...........
- Silverslk
Re: BajaF250
I know we used a certain place when I worked at All American Racers. I'll find out if you want. I'm guessing if it's good enough for them.......it should be fine for us.
- BajaF250
Re: BajaF250
Hey Brian,BDKW1 wrote:Not necessarily, A couple of the shops we use only do regular (type 2). For hard ano I would recommend Symcoat.BajaF250 wrote:So will any place that does anodizing do "hard anodizing?" Anyone know?
Thanks for the link, I'll check 'em out.
- BajaF250
Re: BajaF250
I spent the most greater part of the day in the shop and I got my new brakes installed. And the best part... they work GREAT! I'm not happy with the brake lines so I'm going to reroute them tomorrow.
- THW_2866.JPG (77.32 KiB) Viewed 1447 times
- THW_2859.JPG (74.28 KiB) Viewed 1447 times
Re: BajaF250
Can't wait to hear the details tomorrow.
Re: BajaF250
My vote is for minty green powder coat!
Love the truck by the way, saw you cruising down Magnolia the other day.
- BajaF250
Re: BajaF250
Ah oh, was I doing something bad??Travisfab wrote:My vote is for minty green powder coat!
Re: BajaF250
Saw the beast this morning, brakes are sexy, and the dual rear 3.0s are.......HUGE!
- Agui-E7TE
Re: BajaF250
Its almost like a cool shade of oxidized copper like the Statue of Liberty.
- Becks_Bronco
Re: BajaF250
I was thinking the same thing, as much as this truck is art in metal, it's 100% function.ChaseTruck754 wrote:Yeah - it looks cool & "vintage"
vred
- Jelly
- Bronco Info: 96 Bronco 4x4 5.8, Bilsten Susp, 35 Inch BFG ATs, Custom Bumpers...chase prep BajaHID
Re: BajaF250
100% function and engineering. Tom sets the bar when he does something to his truck.
Re: BajaF250
Chirping it into second gear and 3 wheeling around a cornerBajaF250 wrote:Ah oh, was I doing something bad??Travisfab wrote:My vote is for minty green powder coat!
Love the truck by the way, saw you cruising down Magnolia the other day.![]()
