How will you maintain the gun show?yikes wrote:Change is in the air! Can't wait to stop sawing the wheel.
Looking forward to seeing it completed.
SteveG wrote:How will you maintain the gun show?
Excited to see you back to work on the Bronco and not just the RC car.yikes wrote:It's not a kit. Picked up the heims, misalignment bushings, hex weld bungs and tube from Ruff Stuff. Great prices and they seem to put a lot of effort into quality, cost effective goods. Tube is made by Wheatland. The pitman and swinger are from an unknown vendor. Picked them up at LeDuc's.
This is next on my list!!yikes wrote:Change is in the air! Can't wait to stop sawing the wheel.
B, this will be awesome... can't wait to see it completed and get a full drivers assessment report on the increased driveablilty. This is one upgrade that's on the "must do" list, but it's far off into the future. The one thing I want to add is a ram to protect the sector shaft.yikes wrote:Change is in the air! Can't wait to stop sawing the wheel.
As Philo said these are from Ruff Stuff but a lot of other people make them as wellRandyg12 wrote:Where can you pick up some bungs like those? Would make things a ton easier when adjusting my steering haha.
Bummer... not where you'd like to have slop! Can you take 'em back?yikes wrote:Wow! The misalignment bushings are roughly .640 on the ID. That's ridiculous! The OD's measure anywhere from .7465 to .7489. Shit tolerancing and/or shit quality control. The threads are sloppy in the weld bungs. Not sure if it's the bung or the heim though. They may tighten up after welding, but not across the entire section. The heims ID measure ok and they do have rolled threads, which is good to see. There are so many manufacturers out there that have no clue on fits and tolerances. This shit just pisses me off. In hind sight, I should have just bought one heim and checked it out before going all in.
Call them and talk to them......I've had many friends buy from Ruff Stuff and never complain. Of course, they aren't in your line of work and didn't measure anything.yikes wrote:Wow! The misalignment bushings are roughly .640 on the ID. That's ridiculous! The OD's measure anywhere from .7465 to .7489. Shit tolerancing and/or shit quality control. The threads are sloppy in the weld bungs. Not sure if it's the bung or the heim though. They may tighten up after welding, but not across the entire section. The heims ID measure ok and they do have rolled threads, which is good to see. There are so many manufacturers out there that have no clue on fits and tolerances. This shit just pisses me off. In hind sight, I should have just bought one heim and checked it out before going all in.
That's probably where I'll be headed next Brian. They're always expensive, but right on quality.BDKW1 wrote:After screwing around with shitty misalignments, I now have no problem spending the cash for the Kartek heat treated units. A little antiseize and they pop back out like new........
