Nothing special class3 pics
- ESHALLBETTER
Yep, front bracket was on for a test fit. They will all get powdercoated this week and I should get the back end on this weekend!
The digital protractor came with the Wilson dies when we bought our new press brake. I believe it is a Wixley that they rebranded.
Type "Wixey Digital Protractor" into google. We have the 3, 8, and 18" versions. The 18" is awesome for tube work.
I figured that thing would be cool for tubework. I'd probably get the small one like you have & make a bolt on extension for it.
*edit* - had a quick search online & this looked cheap & cool in case anyone else was interested.
http://www.amazon.com/iGaging-14-Digita ... B002PX6LUS
- ESHALLBETTER
Shackles and leaf hangers are going to get painted tonight!
- shackles.jpg (136.67 KiB) Viewed 1752 times
- ESHALLBETTER
I like to party. I'll finish the motor this weekend and then I'll be needing these!
- MOTOR MOUNTS.jpg (193.8 KiB) Viewed 1726 times
They work better and make less noise with bushings.
- ESHALLBETTER
Bushings wear out and I am a "maintenence free" kinda guy.
It sounds like there's some good progress going on, Erik!
Amen!ESHALLBETTER wrote:I am a "maintenence free" kinda guy.
- ESHALLBETTER
Got everything painted this weekend. I need a couple more bushings then I can put it all together. Got the motor buttoned up, just need to weld the bungs to the valve covers for the PCV system.
- motor1.jpg (290.24 KiB) Viewed 1696 times
- motor2.jpg (282.71 KiB) Viewed 1696 times
- motor3.jpg (279.53 KiB) Viewed 1696 times
- BajaF250
- Bronco Info: 1982 Ford F250
Erik... gorgeous! Nice work!
- johncharlesb
Looking good! Those DUIs are a tight fit, but it looks like you are good. The 71 Bronco had a single plane and a DUI and I had to do some creative manifold work to get it to time.
Will those plug wires clear your headers?
- ESHALLBETTER
I never gave that any thought so I hope so! I will be fabbing the headers, and right now the plan is to go up and back to the firewall and then dump down. I should be able to use these but if not I'll have a good deal on some new/used wires.
- ESHALLBETTER
Rear axle is hung! Still need to install snouts and a fill cap/breather. I think it almost looks cool enough to make me forget how much I hate leaf springs!
- axle sneak peak2.jpg (246.6 KiB) Viewed 1630 times
- axle sneak peek1.jpg (248.13 KiB) Viewed 1630 times
- Becks_Bronco
Looks spiffy
- BajaF250
Wow, that looks great... nice job! Although, one thing, you may have a problem with those U-bolts... they may not be long enough.
- ESHALLBETTER
Yes, they are long, but you will notice I only tightened one so I should be OK.BajaF250 wrote:Wow, that looks great... nice job! Although, one thing, you may have a problem with those U-bolts... they may not be long enough.![]()
marcB
- Bronco Info: 83 Bronco 351W C6 9" ported 7TE heads Comp Cams cam 1 5/8" fenderwell headers
I see Eddy Victor heads, whats the rest of your set-up on the engine? Also what size headers are you building and have you given any thought to tri-y design?
- ESHALLBETTER
I bought all the material a while back, but if memory serves I went with 1.75" tubing. The plan is to head back and up, then dump down along the firewall.
The rest of the motor is basically .030 over stock bottom with new pistons, a motorsports cam (don't remember the specs, I have them saved somewhere) Victor junior heads/intake. C&J carb.
