Michael's 96 Sleeper
Re: Michael's 96 Bronco
35"s look so perfect under the bronco
Integrity, Money, Relevance
1amD1cker1@gmail.com
Michael,
Are the new Deaver Q80 a 3" wide, or 2.5" wide spring? Any pictures?
guard
Post by guard »
tcm glx wrote:Michael,
You know, I failed to take pics when I picked them up. They're sitting down at Marks right now...in the back of my Bronco. I don't recall the width and I remember even asking the question when I was at Deaver! I do remember them saying they designed it so Bronco owners wouldn't have to run the F150 spring anymore. I also recall Mark saying they were able to take a little more of a load/weight. I would think they'd be really good for a prerunner with that extra "junk in your trunk".
I think Solo Motorsport is even offering it now as an option along side the F53 in their rear suspension kit.
Deleted Account
Post by Deleted Account »
They are 2.5 Tony. Its an f53 with one more leaf. should have the same ride height with more load carrying
mkiefer wrote:They are 2.5 Tony. Its an f53 with one more leaf. should have the same ride height with more load carrying
Interesting, when the F53s need a rebuild, I will see if we can spec out the same as these!! Post up some pics Mark...
guard
Post by guard »
We discovered the spare tire carrier was not going to last, starting to crack on the side and tear up the gate. Sadly I haven't even put the 35" spare on it yet! So, options are to put the tire inside or find a better tire carrier. Well, I don't want to diminish space inside so another rear tire carrier it is! I contacted Protofab and they're working on a rear bumper with tire carrier for me, about 30 days out. It can handle up to a 37" tire.
http://www.protofab4x4.com/products.php?ID=00&ID2=74
Picture of the bumper w/ tire carrier (not my bronco)
guard
Post by guard »
So, took a trip to Mark's place yesterday to drop off a few supplies ($450 worth of Schaeffer products), talk about the build and take his Bronco out for a spin. It was really neat to see his current projects and experience the gofast suspension he creates. Cool stuff! Anyway, we talked and decided to nix the plan for Bilstein 5165's in the rear and replace with a Bilstein 9100 short body (2.65). We also added some minor axle trusses to the build with a little axle protection for rock crawling.
Lubricants we're using:
Motor Oil - Schaeffer Supreme 7000 Synthetic Plus 5W-30
ATF - Schaeffer #204S ALL TRANS Supreme Transmission Fluid
Power Steering Fluid - Schaeffer #204S ALL TRANS Supreme Transmission Fluid
Diff oil - Schaeffer #293 Supreme Gear Lube
guard wrote:So, took a trip to Mark's place yesterday to drop off a few supplies ($450 worth of Schaeffer products), talk about the build and take his Bronco out for a spin. It was really neat to see his current projects and experience the gofast suspension he creates. Cool stuff! Anyway, we talked and decided to nix the plan for Bilstein 5165's in the rear and replace with a Bilstein 9100 short body (2.65). We also added some minor axle trusses to the build with a little axle protection for rock crawling.
Good stuff Michael!! When is the maiden voyage?? This thing will rock for sure.
guard
Post by guard »
tcm glx wrote: Good stuff Michael!! When is the maiden voyage?? This thing will rock for sure.
Hah, good question! I predict around the end of January, depending on a few parts that Mark's waiting on. If it's ready before the Pismo trip, I may be there. I told Mark the drop dead date was prior to KOH... haha
What day will you be at KOH?
guard
Post by guard »
tcm glx wrote: What day will you be at KOH?
I'm planning to roll in late Weds afternoon or early Thursday morning, leaving Sat late afternoon. You?
Where are the updates Michael?
guard
Post by guard »
Ok Tony, here's an update :P
Mark's been busy...keeping a steady supply of pics headed my direction too!
New Ruffstuff battery box and yellow top with 1/0 gauge wiring
Stripping down...
Mag-Hytec 4R100 Deep trans pan
Mark's handiwork 8-)
Inside look at the brand new front elocker...functioning perfectly.
Old braided brakeline getting replaced with new stuff, good thing too :o
Relocating fluid reservoir
Done.
guard
Post by guard »
Candy back from powder coating
Side view
Driver's side preparation
Shock tower installed
Passenger side preparation
TTB
Shock tower top view
New Deaver Q80's
Looking really good!! WOW, he has been making some seriouus progress on that thing! You already get your shocks?
guard
Post by guard »
tcm glx wrote:Looking really good!! WOW, he has been making some seriouus progress on that thing! You already get your shocks?
Thanks! I'm headed out to Mark's this coming Saturday to survey the scene myself. Unfortunately no Pismo this year for me, but I do still plan to make KOH.
Mark's working on the shocks, don't believe we actually have them yet...
Another awesome build! Well thought out. Looking forward to the end result. What exactly are the Q80's built for? Haven't heard that number before.
guard
Post by guard »
yikes wrote:Another awesome build! Well thought out. Looking forward to the end result. What exactly are the Q80's built for? Haven't heard that number before.
mkiefer wrote:They are 2.5" wide. Its an f53 with one more leaf. should have the same ride height with more load carrying
I'll defer to Mark on this...
Deleted Account
They are a 2.5 inch wide bronco spring.. a little more load carrying capasity then the f53. basicly its an f53 with 1 extra leaf..
guard
Post by guard »
Mark found a good spot to fix the new Rigid Dually switches (front/rear) installed next to elocker switch. Thanks to Chris @ Philofab for supplying rear light!
