1987 XLT "Bob's White One"
Bondobob
Post by Bondobob »
Ok I had done 4 turns, I will dial it in. Thanks for the info on the radius arm I was not sure that it needed a spacer behind the "3rd" bolt tab, but in doing that it would make alignment easier(less of a bind condition).
The Heim connection boxes were installed as per Autofab measurements of old mount rear side frame rivet to new mount front side frame bolt hole.
Elwood Blues -1980
MOSS2
Post by MOSS2 »
I seems that if you are still using bushings for the beam pivots not uniballs you should not push the beams forward. The bind condition would not do much positive for their life. Lookin good.
Yes, Moss is right, the bushings will not last as long when you push everything forward. My crew cab used to get beam bushings every other oil change.
I normally push everything forward and cycle. Once I find the maximum point forward (when the axle hits the pivot) I move it back so create more clearance. Don't forget everything will be flexing around.
3/4-1" is about max you can pull off. Maybe less due to your additional material on the pivot.
Updates for us Bob.....
Bondobob
Post by Bondobob »
Driver side pics
No more rivets
No more rivets
Dside mount2.jpg (34.62 KiB) Viewed 2877 times
Elwood Blues -1980
Bondobob
Post by Bondobob »
Steering has been very sloppy, I was amazed how much play was in the old steering shaft. New Borgeson was fitted and removed for driveway rattlecan( yes Steve I used self-etching primer before paint).
Elwood Blues -1980
Looking good!
Stop what you're doing Bob, and get an RC truck! :mrgreen:
Looking good!
Bondobob
Post by Bondobob »
Hey I am a member in good standing with Projects Anonymous...... I have a few in the holding pattern that need attention before I fall off the wagon!
Elwood Blues -1980
Bondobob
Post by Bondobob »
Buckets mounted and playing with cycling to determine shock tab locations and then I will pull it apart and rattlecan the unpainted stuff and do a final assembly.
Elwood Blues -1980
Bondobob
Post by Bondobob »
Need to adapt the factory bumps on the bottom of the Spirit Racing coil buckets. More Pics....
Doing some maintenance stuff as well I pulled throttle body for a parts washer spa day cleaning. Upper intake will get the same treatment so I can replace valve cover gaskets and keep the 302 running for a while until I rebuild the 351 and E40D that I have waiting.
Elwood Blues -1980
Bondobob
Post by Bondobob »
Some update pics on the '87.
Got the shocks cycled and tabs tacked ready to tig. Gotta get a 60 degree or 90 degree adapter to clear the A/C evap so I can drop resi and mount low or rotate up and mount on cross bar.
Elwood Blues -1980
Bondobob
Post by Bondobob »
Completed maintenance stuff on 302..... new valve cover gaskets, new intake gaskets new vac lines and pulled and cleaned 25 years worth of "unburned hydrocarbons" out on the intake, T/B and EGR passages.
Elwood Blues -1980
Bondobob
Post by Bondobob »
Now the Autofab parts are coming off and the "stock stuff" is going back on the '87. I got James' 1996 E/B Bronco and I will start a new thread on what I am going to do to that one. All I can say is that the MAF 5.8 roller motor runs alot better that the 1987 SD 302!
Elwood Blues -1980
Bondobob
Post by Bondobob »
The '87 won't stay completely stock, but will get a few low $$ mods and probably get inherited by my son(Since it was his grandmothers since new) when he graduates from college.
I scored these at the Swap meet for a crazy low price...So now I need some leveling coils and some shocks, Solo built these and they locate the upper 2.5" higher than stock in a double shear..cool for mild set-up the Bronco will get now, The 1996 stock beams and arms will be installed on the 1987.
Elwood Blues -1980
Bondobob
Post by Bondobob »
Ok the stock beams and radius arms came off the 1996 EB and got cleaned new moog pivot bushings, I took my old 1987 OEM limited slip D44 and put new seals in it and its ready for another 10-20 years now I guess.....
Elwood Blues -1980
Bondobob
Post by Bondobob »
Well I cannot post any photos, I am getting a "Sorry, the board attachment quota has been reached." message.
Elwood Blues -1980
Bondobob
Post by Bondobob »
Ok Some pics. Mostly stock and with the modified buckets I can run a 6.5" travel 5100 with a Moog cc824 spring.
Elwood Blues -1980
Bondobob
Post by Bondobob »
Another, I will get some more after I install the rest of the parts.
Elwood Blues -1980
Mojo
Post by Mojo »
I like!!!
