While I get the not mixing & matching I'm agreeing with Andy on this one. I'd definitely avoid mixing & matching beams & radius arms from different builders unless you talk to the builder to see where the caster is built in, what angles they are at, etc.
But for the "engine cage" kits (more of an upper shock mount really) all this does is hold the top of the shock - like Andy said. IF there are lower shock mounts already on the beams (or radius arms) then mixing & matching here could cause a little issue, but if there are no shock mounts yet - then mix & match away on shock hoops & build the lower shock mount to work with that.
I missed it cause I was in the back working and then I called it back and got some secret government research facility.Silverslk wrote:Called you yesterday but you probably saw the 818 number (desk) and was like "What the hell?". hahahaphilofab wrote:Yo! Andy, I thought you were going to call me?
I'm not a message leaver so I hung up.
- SuperSixAxis
- Bronco Info: 1996 5.8, E4OD
Andy, lots of good info on Ricks ride at Autofab.com. I would think John would probably give some advice as well.
- Silverslk
OK. I went out and took some pics of the beams I have. They are made by BTF Fabrication. I have not called them yet to discuss anything. I just wanted to post up some pics and get opinions on them and if you see anything else I should do to them before starting to install. I value everyones opinion on here so please....speak up!!
- IMG_6759.JPG (91.81 KiB) Viewed 2053 times
- IMG_6760.JPG (107.14 KiB) Viewed 2053 times
- IMG_6761.JPG (90.15 KiB) Viewed 2053 times
- IMG_6762.JPG (91.92 KiB) Viewed 2053 times
- Silverslk
more
- IMG_6763.JPG (82.38 KiB) Viewed 2053 times
- IMG_6764.JPG (86.62 KiB) Viewed 2053 times
- IMG_6765.JPG (100.84 KiB) Viewed 2053 times
- IMG_6766.JPG (111.69 KiB) Viewed 2053 times
- Silverslk
Last of em
- IMG_6767.JPG (92.49 KiB) Viewed 2053 times
- IMG_6768.JPG (89.87 KiB) Viewed 2053 times
- IMG_6769.JPG (89.38 KiB) Viewed 2053 times
- IMG_6770.JPG (88.1 KiB) Viewed 2053 times
Andy, I would plate the backside of the driver's beam all the way to the center section. That area has a tendency to crack. Looks like BTF does nice work. That's not Blue Torch Fab is it?
- Silverslk
Thanks B!! I wondered about that part. I saw alot on here plated all the way but this is why I asked. and no it Brandon-Travis Fab. http://www.btf-fab.com/
I really like the stuff so far and can't wait to get it on.
It need black spray paint to be ready to go.
- baja-chris
They look great. Paint em and run em!
They need powdercoat and glossyness action!!Silverslk wrote: I value everyones opinion on here so please....speak up!!
- Silverslk
Except yours!!tcm glx wrote:They need powdercoat and glossyness action!!Silverslk wrote: I value everyones opinion on here so please....speak up!!
It only costs 99 cents to make beams with spray paint look new again...
Eh - those beams look like crap Andy - you should just give up on them & donate them to me!
- SuperSixAxis
I hate seeing rust...on anything! Its like the earth is stealing our parts! LOL
- only1mikey
- Bronco Info: 84 Bronco
Wow those things sure rusted up fast! They were rust free when they left my place.
But I guess that's what happens when you live right by the beach!
Mike
Mike
- Silverslk
I blame Chris!!!only1mikey wrote:Wow those things sure rusted up fast! They were rust free when they left my place.
Mike
Chris is a few miles inland for sure - you should see stuff at my place. I blink and the stuff rusts!
- Bronco Broker
I actually almost had them media blasted before I posted them for sale but assumed someone would probably p coat them before installing.Silverslk wrote:I blame Chris!!!only1mikey wrote:Wow those things sure rusted up fast! They were rust free when they left my place.
Mike
- Silverslk
While not a special update or even go fast. Its still an update.
I managed to score some OEM floor mats on Ebay for the front. I have been running without and worrying about ruining the carpet.
I also did the Ford "Dash fix" by getting my buddy at the dealer to locate one of the few left in the country. The tab had broken clean off and the dash had been shaking up and down 2-3 inches easy. I didn't know it was broken or about the fix until Tony told me.
Last, my wife decided to get me custom plates for Valentines (they showed up 4-6 weeks after). They are based on the nickname around some friends as the "Turtle". They (friends) claim its because of its color and that I say its a "slow build" but either way......I own it now.
- IMG_6824.JPG (64.92 KiB) Viewed 1740 times
- IMG_6827.JPG (32.99 KiB) Viewed 1740 times
- IMG_6830.JPG (83.92 KiB) Viewed 1740 times
