1987 XLT "Bob's White One"
- Bondobob
The parts are staged and its time for tear down.....
- IMG_3754.JPG (37.84 KiB) Viewed 1627 times
- IMG_3753.JPG (36.5 KiB) Viewed 1627 times
- more parts
- IMG_3752.JPG (30.6 KiB) Viewed 1627 times
- Parts
- IMG_3751.JPG (34.89 KiB) Viewed 1627 times
Elwood Blues -1980
Elwood Blues -1980
- Bondobob
Rear with stock bumper and tire carrier before removal
- IMG_3756.JPG (33.03 KiB) Viewed 1627 times
Elwood Blues -1980
Elwood Blues -1980
- Bondobob
Without... I will post in the parts but if anyone needs a stock bumper with brackets it is yours if you will donate some $$'s to the wounded warrior fundrasier. Also goes for the 8.8 rear end, springs and coils, buckets etc. The knuckles, hubs and rotors are spoken for but all else will be listed in the parts as stuff I pull off is open for grabs just paypal some coin to Steve G.
- IMG_3759.JPG (35.09 KiB) Viewed 1624 times
Elwood Blues -1980
Elwood Blues -1980
- Bondobob
Tear down begins in the AM
- IMG_3763.JPG (70.08 KiB) Viewed 1624 times
- IMG_3768.JPG (185.94 KiB) Viewed 1624 times
Elwood Blues -1980
Elwood Blues -1980
Right on Bob.... glad to see you are getting her done!!
BTW, ny neighbor will probably want to take that 8.8 off your hands...
Lookin' good. You've got about a month and a half to get it done!
- Bondobob
Yeah I'm hoping to hammer hard for the next 5 days and get most of the change over complete. Once the front is naked I will need a little input on the best location for my shock mounts. I am re-using Randy(HTO's) spirit racing coil buckets and I will fab up some new upper mounts on the upright risers for my 10" SAW's.
Elwood Blues -1980
Elwood Blues -1980
- Bondobob
Tony, If he wants it is his just make sure he donates to the paypal account Steve G set up and we can work out delivery.......
Elwood Blues -1980
Elwood Blues -1980
Awesome Bob! I'm very excited for ya!
Looking good Bob - can't wait to see you go to town on this thing - I bet you're excited!
- DirtFiend602
- Bronco Info: 86' go faster
Hooray for giant piles of parts! Where did you get the coil inserts from? those things are the bees knees.
You can get them from Autofab.DirtFiend602 wrote: Where did you get the coil inserts from?
- Bondobob
I'm committed now!
- 87front7.JPG (183.9 KiB) Viewed 1560 times
Elwood Blues -1980
Elwood Blues -1980
- Bondobob
I got the springs from Kritter and he had used the inserts so I just put them back in the springs. I may need to add some more material to fill the coil at ride height once I cycle everything.
Elwood Blues -1980
Elwood Blues -1980
- Bondobob
Another bare pic
- 87front2.JPG (38.92 KiB) Viewed 1559 times
Elwood Blues -1980
Elwood Blues -1980
- Bondobob
Big surpise came when I pulled the pumpkin and it was an OEM Dana factory limited slip 3.54 and it is very clean. This will be up for donation to the wounded warrior project. I am sure that it would be valuable to someone here or someone on FSB let's see how much it can bring for the good cause.
- IMG_3762.JPG (33.67 KiB) Viewed 1555 times
- IMG_3760.JPG (29.27 KiB) Viewed 1555 times
- IMG_3761.JPG (34.71 KiB) Viewed 1555 times
Elwood Blues -1980
Elwood Blues -1980
- SuperSixAxis
- Bronco Info: 1996 5.8, E4OD
Bob, what a cool buildup man! This one will be subscribed to for sure. How many teardowns have you done and what travel #'s are you looking for front/rear? is 16/16" about right for you?
- Bondobob
James, I'm poppin' my cherry on this one. I've built hot rods and harleys for years, but I have always liked the Broncos and a multi-purpose rig is very appealing. I don't really have a set travel target(14-16" is where it may net out) I just want the Bronco to be reliable/capable and fun to play with and a little forgiving if my self discipline goes away....
Oh and one more pic there just has to be one rivet that refuses to yield. I will use more aggresive removal means in the AM.
- IMG_3765.JPG (31.85 KiB) Viewed 1541 times
Elwood Blues -1980
Elwood Blues -1980
- Bondobob
Mocked up one side get an idea for placement and preparing for drilling and fasteners. Question now is shock mount orientation. The location will be behind the bucket with the lower mount positioned on top of the radius arm to keep the shock body positioned 1/2"-3/4" from the rear of the bucket body and frame surface.
Is it best to set mounts at full extension, compression or an estimated ride height????? and is my planned clearance satisfactory?
- 87passm1.jpg (26.81 KiB) Viewed 1523 times
- passbk1.jpg (33.9 KiB) Viewed 1523 times
- passbk2.jpg (35.96 KiB) Viewed 1523 times
Elwood Blues -1980
Elwood Blues -1980
- Becks_Bronco
What is your reasoning for putting the shock behind the bucket?
Most with single shock setups run it in front. I don't have enough knowledge to tell you why, but i believe it has more leverage that way.
Just curious.
Just curious.
