1997 f250 prerunner build
jimmyd
Re: 1997 f250 prerunner build
Post by jimmyd »
blew a head gasket about a month ago.
I had the heads ported, put a extreme 4x4 comp cam in, new water pump, plugs, wires, EGR delete, smog pump delete, long tube headers.
took out core support, and relocating radiator to rear with electric fan from 3.8 taurus.
engine going back together
IMAG0113 (480x640).jpg (116.47 KiB) Viewed 3418 times
IMAG0124 (640x427).jpg (189.43 KiB) Viewed 3418 times
IMAG0125 (640x427).jpg (154.44 KiB) Viewed 3418 times
Wow, how did I miss this one? Where abouts in KC are you?
BTW, the radiator set-up like that will not work well...........
Bed-mounted radiator... that takes me back. Mine worked OK but I had a larger radiator, dual fans and I put a scoop under the truck.
Had I to do it over, I wouldn't.
The airflow on that thing at speed is probably not the greatest.... especially with a complete bed floor.
Out of curiosity, what made you move it there?
jimmyd
Post by jimmyd »
Olathe,ks, fish out of water for sure.
moved it for several reasons, mainly practice for my other truck. also the core support was totally rusted out along the bottom 1", and a new one was $200 and i didn't spend not half that doing it this way instead. finally i think it looks cool, and thats about the only reason i need.
as far as not working well, if it doesn't (just like everything else i have completly built and designed by myself without another truck like it within 1000 miles of me) i will figure out a better way to do it.
new front support.
IMAG0129 (640x427).jpg (133.28 KiB) Viewed 3370 times
jimmyd wrote:Olathe,ks, fish out of water for sure.
Pretty much, I'll be back in Easton within the next couple of years.
jimmyd
Post by jimmyd »
yeah i am not from here. had to look up to see where Easton is. not far from Olathe though. why you coming back here?
60 acres to build a house and shop on. Also, there are more machinist jobs in KC than in SD and they pay the same or better.
jimmyd
Post by jimmyd »
Yeah I hear ya that's why I left SD. Do you ever make your way back out here? if you do, love to meet up.
Will be there for thanksgiving rebuilding a bobcat motor......
BDKW1 wrote:Will be there for thanksgiving rebuilding a bobcat motor......
Change the fuel tank while it's out if it's even close to needing one.
jimmyd
Post by jimmyd »
Mmm turkey , stuffing, and oil... that's American...
SuperSixAxis
Bronco Info: 1996 5.8, E4OD
Post by SuperSixAxis »
So this is where babies come from! LOL
Seriously though, this is cool. Cannot wait to see the new cooling system setup.
Joxracing
Post by Joxracing »
Coming along nicely Jimmy. This truck really gives me examples and inspiration for mine. I'm in the same boat you are too, not a truck like us with in 1000miles, and no one knows what they are, or what they do.
Look for some of you're ideas on my nite edition... hopefully.
jimmyd
Post by jimmyd »
Joxracing wrote:Coming along nicely Jimmy. This truck really gives me examples and inspiration for mine. I'm in the same boat you are too, not a truck like us with in 1000miles, and no one knows what they are, or what they do.
don't forget, i have built and designed (with drawings) every suspension piece on my truck. actually i have a set of shock hoops already bent up and ready to go, just need to make the engine x-member. so if you need any of these parts let me know.
as far as cooling goes, it seems like it was working pretty well. however, i definetly need dual fan with a shroud because it would slowly start creeping up, and i wasn't doing anything too hard with it. and then, like a dummy, i put the 5.0 (that i am going to build as a race engine for my 2000 f150), into the bed, and it rolled, barely bumping into the radiator. it didn't damage the actual radiator, but the plastic mounting tabs cracked slightly, letting a small amount of coolant start to leak. so it will be out of commision for a few weeks until i buy a new radiator. let you guys know more then.
thanks for the good words guys. i will be starting a new thread soon on the front end build for my 2000 f150. I just got my shipment of 100' , 2''/ .120 wall DOM. And also, like I said before, my J/Y 5.0. I also ordered a Miller XMT 350, MPA package, for my fabrication business.
jimmyd
Post by jimmyd »
i bought a raptor, my F250 would wreck it off road though.... might start parting the F250 out.... at least, the tire carrier, bumpers, and light bar. maybe suspension we'll see. way to busy to do anything with it.
IMAG0187 (640x427).jpg (171.04 KiB) Viewed 3059 times
Joxracing
Post by Joxracing »
how much would you want for the lightbar, rear bumper, and tire carrier?
That all should bolt up to my 89.
oh, what do you have for rear suspension parts?
jimmyd
Post by jimmyd »
The Raptor a year later
IMG_6812 (620x413).jpg (249.34 KiB) Viewed 2754 times
IMG_6849 (620x413).jpg (220.43 KiB) Viewed 2754 times
IMG_6744 (620x413).jpg (194.04 KiB) Viewed 2754 times
Saw pics of that Raptor floating around FaceBook a few weeks ago, love the ODG!
jimmyd
Post by jimmyd »
Cool! Yeah its been shared( Or whatever you guys say on the Facebook) quite a few times, like 4000 or something. Facebook.com/whitestarindustries you can see more pics
