HTO'S BRONCO BUILD
Re: HTO'S BRONCO BUILD
hobbyturnedobsession wrote:Yes sir! I'm also going through the hack job of the po, on top of my quick fix its. Its a mess but its getting better. She and I am definately going next time, and I will be better prepared. I destroyed my tool box on the last trip.
Pics of the cutout Randy!! You know I am going to call you to help me do mine... hahah
Hahaha its scary man, I yanked probably 10 feet of wire yesterday and 8 feet of it was dead wire.... IT SUCKS!!!
One of you guys building access panels needs to take lots of photos and post them in the Tech section.
Hahah I'll probably botch the crap out of it.
So far we've got Rick, Randy & Nick with scrap from me to do this. Who will be the 1st to post pics? Looks like Randy is the only one who has started so far.
ChaseTruck754 wrote:So far we've got Rick, Randy & Nick with scrap from me to do this. Who will be the 1st to post pics? Looks like Randy is the only one who has started so far.
Looks like I maybe going towards a 45 gallon tank on my silver Bronco Steve. Let me know if you run into any more Bronco rear cargo floor sections.
Next one I get would be for converting the back of the supercab if I do it - so I will be keeping it. Unless that is I find a 80+ bronco for diiiiiiirt cheap and you buy it for me in trade for cutting the rear floor out :D
Don't do it man, don't covert your extra cab into a Bronco.
SteveG wrote:One of you guys building access panels needs to take lots of photos and post them in the Tech section.
Ok, so I didn't take a lot of pictures, but I did take a couple (took them while I was building the bed). I posted in tech in the general section... fuel access panel... Let's see how everyone else is doing it!
So its not complete but is definately workable and I love having them on the column rather than spread across the dash. I ran a switch for the lights and a now separate switch for the trans fan. Also, I don't have matching gauges yet but they all do work.
gauge pillar.jpg (48.45 KiB) Viewed 1045 times
gauge pillar 2.jpg (49.79 KiB) Viewed 1045 times
So, after watching poor Carly bounce around in baja I decided to pick up some seats. I put in the drivers seat for test fit.
seat frame.jpg (31.13 KiB) Viewed 1003 times
seat 2.jpg (50.26 KiB) Viewed 1003 times
seat 1.jpg (70.3 KiB) Viewed 1003 times
So an update. I finished mounting both seats and harnesses. Now I'm working on the rear bench seat mount. My attempt will be to make a seat mount where I can unbolt the seat and there is a mount there ready for my supplies to be sinched down. Not the easiest but I thought it would work good.
rear seat mount.jpg (31.76 KiB) Viewed 946 times
Getting better at welding.
weld close up.jpg (96.25 KiB) Viewed 946 times
Well heres a few more pics of the rear seat mount / crap holder. There will be a bar between the two ammo cans, I need to make one last cut on the bottom portion of the leg mount. The way I see it, it should mount to the two existing bolt holes up front and the two in the center in the rear. The seat will unbolt and I can carry all my stuff without stuff flying everywhere.
bottom view seat mount.jpg (67.52 KiB) Viewed 925 times
rear seat mount.jpg (26.02 KiB) Viewed 925 times
half packed.jpg (45.94 KiB) Viewed 925 times
Nice work Randy. You'll love the suspension seats I'm sure.
Thank you. Oh I do trust me. I've got a bucket bench for the rear I am sure the passengers will love too.
cuz_im_CR
Bronco Info: 96 xlt stock
Post by cuz_im_CR »
looks great man, who makes those seats?
Thank you. The rear seat is a PRP for a rhino. I picked it up brand new on the cheap. The fronts are also PRP seats I bought from a friend of mine.
So, I decided to see exactly what it looked like before I mounted it. Heres what it looks like.
rear seat mount stuffed.jpg (58.06 KiB) Viewed 859 times
Nice - you have any strap mounts on the thing you so can strap the stuff down and keep it from flying around while the truck bounces all over the place?
Hahaha it will by the end of the day. I set it in to make sure it fit.
