Barge #3.......... Eventually........
Re: Barge #3.......... Eventually........
Oh, I'm always working, just not on My stuff.........
Like today.
you and I both know what I meant ;)
At the 500 I started talking about converting my '74 supercab to a bronco. Luckily I was quickly talked out of it. I still really like the idea just have no time.
what are you doing to the Blue Bronco?
I dream of his suspension setup... Can i have a closer pic of the front?
I want those wheels.. Who makes them?
Integrity, Money, Relevance
1amD1cker1@gmail.com
Good luck on the wheels. APP will still make them for you if you want to buy about 500............
More pictures of it here. http://jdfabrication.com/index.php?opti ... &Itemid=68
Red neck body lift....... Damn tree barely even flexed.
GTFO and don't come back..........
Who took the chassis?
ChaseTruck754 wrote:At the 500 I started talking about converting my '74 supercab to a bronco.
DO IT!!!!!!!!!
baja-chris
Post by baja-chris »
Notice the licence plate on the truck that towed it away. Old class 8 dude. 1Baja99
baja-chris
Nick wrote:Who took the chassis?
It was towed away to serve a better life. You are likely looking at the 2012 Baja 1000 Class 3 winner there! Ha.
You sneaky bastage!
Brian, we (meaning me) need updates on this. Did your other project leave? If so are you at least looking at this thing again? With my new brain fart brewing I really need you to start this before I start mine so I cna see how it's done!
Yeah, I got an update! My rear sending unit still doesn't work. friken tank conversion........
as usual - not what I was expecting or wanting - haha
Maybe this will be a bit helpful. Not that you need the cab matchup like I do, but pics may be useful??
I was at the shop last night and I dawned on my I had a scrap pile of what used to be an '87 bronco since my buddy still hadn't taken the load to recycling yet. I cut a bit more off this bronco hunk and held it up to my supercab (still not cut well enough to fit right obviously, but this was a quick test). I was wondering if I might be able to get away with a 80+ donor for the bronco half since I can run a 778/79 tailgate on it and only this section above the bedside would show due to fiberglass bedsides. Looks as if I might need a 78/79 donor to make is a smooth blend from the supbercab to the shell connection part on the bronco. It looks almost doable from the side but you can see the cab angle difference in the 3rd pic.
x 164.jpg (115.6 KiB) Viewed 1550 times
x 163.jpg (95.8 KiB) Viewed 1550 times
x 166.jpg (90.07 KiB) Viewed 1550 times
x 165.jpg (170.01 KiB) Viewed 1550 times
You know, I had checked the profile of the Broncos against the newer body style trucks. How cool would a 4 door extra cab body with a Bronco back be......... They weren't close enough to make me want to attempt it.
Superduty style cabs? I think it would be close....
BDKW1 wrote:You know, I had checked the profile of the Broncos against the newer body style trucks. How cool would a 4 door extra cab body with a Bronco back be......... They weren't close enough to make me want to attempt it.
I've seen them in the 70's truck bodies. A couple guys have made these road trains. Damn they are loooong!
Update, fixed the sending unit. Seems it was working fine but the brass float had a hole in it. Safety wired the stock diesel plastic one to it and it's all good now. I was think of tack welding them together, but the chance of fire seemed pretty high.......
Also figured out why it would only pull fuel above half a tank. Put the pick up extension on the wrong tube....... The Bronco sending unit with the in tank pump had 2 tubes in addition to the return. It only took a second to realize that I had picked to one that went nowhere for the extension.........
Then it was time to figure out why I had no parking brake and what the growling was coming from the D-side rear drum......... As I was beat uselessly at the drum trying to free it I happened to be looking at the leaf pack. Odd, there seems to be a notch in the main leaf. As I bent down to get a better look I noticed I could see all the way through it. Cool! So I went a picked up these.
After fighting the u-bolts for about 30 MIN I decided to cut them off and replace them. Napa didn't have any replacements on hand and it would be 28$EA and 2 days to get them. So I reused the stockers after a good wire wheeling and left out the overload spring to make them long enough.
While attempting to get the springs out I realized I couldn't get the shackle bolt out with the service bed on it. So I drilled a hole in the service bed to get to it......... The nut promptly rounded off. It was at that point that I determined the springs would have to be cut off and that project was going to wait till the service bed was gone. So I welded the stock spring back together and bolted everything back up minus the overload spring due to the newly shortened U-bolts.
So now that thats all sorted out and I replaced all the missing brake parts, it's time to build radius arms and mounts for these.
Are those Dirt Logic shocks off a superduty? 10" stroke?
Will that work on the front?
Yes, they come in 3 lengths, Roughly 7-8-9" travels. These are 8". Should get about 11" of wheel travel. Since a SD is a strait axle and I'm TTB, they should end up being a little softer than on a SD. Should be real close though.
Wanna make 2 sets of Rad arms? Or at least just make a fixture & let me borrow it... I'm getting lazy in my old age - haha.
