The picture and comment above will make more sense with this:
Hmmmmmmm,
- user20433_pic6362_1305050633.jpg (53.35 KiB) Viewed 2114 times
I didn't know you had finished the new party barge already...BDKW1 wrote:Hmmmmmmm,
Dust
I suddenly feel like an amateur Rednek!
Hey! My long lost cousin Brendan. What a small world it is.philofab wrote:The picture and comment above will make more sense with this:
No that thing is SEXY! Shows all you fools what really should be done with a bronco!BDKW1 wrote:Hmmmmmmm,
- bajascott
- My belly is my best friend
it looks like a hot wheel. but kinda cool cuz its different
"They see me roellinnnn'!"
- Deleted Account
Should be "intresting"philofab wrote:
Geoff Falzone from Giant has gotten himself a Bronco. He is installing a DDL link setup in it.
Mark Kiefer
Southwest Performance
858-449-2292
Pics
858-449-2292
Pics
I STILL cant figureout how that set up works......
EDIT: Just checked out Giant's website. Sorry, don't like the idea. A track bar in the rear limits travel too much, isnt strong enough and the roll centre is asymetric. OK for mall cruisers but I doubt it will work in real world racing or rough stuff. Just my opinion.
Dust
Been working on a similar set up for the front of a SA Bronco \ 1/2T off and on for a long time.AusBroncodoc wrote:I STILL cant figureout how that set up works......
Track bar is long enough that it's effects are not noticed. The only thing limiting travel on a Bronco is the driveshaft. It has all ready been proven on many Rangers. It actually works surprisingly well.AusBroncodoc wrote:A track bar in the rear limits travel too much, isnt strong enough and the roll centre is asymetric. OK for mall cruisers but I doubt it will work in real world racing or rough stuff. Just my opinion.
BDKW1 wrote:Track bar is long enough that it's effects are not noticed. The only thing limiting travel on a Bronco is the driveshaft. It has all ready been proven on many Rangers. It actually works surprisingly well.AusBroncodoc wrote:A track bar in the rear limits travel too much, isnt strong enough and the roll centre is asymetric. OK for mall cruisers but I doubt it will work in real world racing or rough stuff. Just my opinion.
Mate, NO track bar is long enough if you expect to acheive decent wheel travel without the axle walking across the car and back. Rangers can run longer beams to offset the driveshaft problem, but a track bar seriously limits wheel travel without the axle stepping sideways back and forth. I used to race Range Rovers, so I know how the track bar works (and limits) wheel travel. Mine was 10" longer than factory and still limited travel to 11" max on the front axle. Obviously Giant made it work, but I dont see it being a real step forward except as a cheap compromise option to a real 4 link. Again, just my ignorant 2 cents.
If your that concerned just run a watts link. That setup also doubles as an anti sway bar. Its intended for street vehicles that are emissioned so you don't have to move the fuel tank.
Again, a Watts link only locates the axle for sideways movement, it does not act as an anti sway bar of any kind. Thats exactly what that psuedo link thingy was designed for, so the mall cruisers can pass smog with the factory fuel tank. I STILL dont understand how those King things work to stop the axle rotating forward or to articulate it.philofab wrote:If your that concerned just run a watts link. That setup also doubles as an anti sway bar. Its intended for street vehicles that are emissioned so you don't have to move the fuel tank.
Warn hubs are crap. Auto is where it's at. 170K with no auto hub failures, then I screw it up with manual hubs.
Dust
Warn hubs are crap. Auto is where it's at. 170K with no auto hub failures, then I screw it up with manual hubs.[/quote]
Now there is a
laugh! Thanks!
Now there is a
Guys, this is a pic post. Take it to the tech section!
I posted a video, but it's not working. Where is the video thread?Nick wrote:Guys, this is a pic post. Take it to the tech section!
