NavyNukes 82 Build
navynuke
NavyNukes 82 Build
Post by navynuke »
Picked up a bone Stock 82 Bronco.
Had a few dumb prior owner things that needed fixing, electric fuel pump on the valve cover, terrible mud tires, a few other things like that.
fresh tires, fixed a few problems from the prior owner and a couple of HID's on the stock bumpers, and she was ready to start being used and abused.
Then I bought a couple of bumpers off a parts truck in town
then decided I wanted the whole truck, and went to buy the entire truck
Pulled the 4" ranch lift, both axles with 4.10 gears and ARB lockers out of the parts truck
ARB switch panel I made up
then she needed some tires, the 31s looked a bit out of place
so on go some Cooper 35 STTs
navynuke
Re: NavyNukes 82 Build
Post by navynuke »
Better for playing around, I do a bit of everything with the bronco
Then I took the next step towards making it safer
I had a full cage put in, 1 3/4 120 wall tubing tied to the frame
Then while completely gutted I decided to paint her, as the factory brown was flaking off and being replaced by rust of the same color.
Then Philo sold me some Camburg Coil Buckets, as well as SAW 2.5 race runner shocks
made a few changes to my front bumper to incorporate the new 7" HID's
Need to get some limit straps, then start thinking about the next step. I have some a motor to start rebuilding too, as the 200k mile 302 thats in the bronco is getting a bit tired.
Kyles95
Bronco Info: '95 Bronco XLT custom 2.5" lift 32x11.5 BFG AT soon 4 inch and 33's via cut/turn beams
Post by Kyles95 »
Your trucks looking good bro, I'm jealous of the Camburg buckets and Sway-A-Way's! That's my next step. Looking forward to whats next.
navynuke
Post by navynuke »
Whats next was supposed to be a motor that I started pulling apart.
but I tried my hand at some rock crawling, and broke a few things.
tie rod
stripped out a warn hub
and broke a couple of teeth out of the spider gears in the ARB unit in the 8.8
So faced with deciding if I want to replace the ARB in the 8.8, or put gears and a detroit into the 9 inch axle that started under my truck.
I'm leaning towards the 9 inch, but open to suggestions.
Hey Ken,
Who did your cage work?
navynuke
Post by navynuke »
guy here in town named Nick Lyons. Works for the power company during the day, does fabrication in the evenings out of his house.
Did you save your stock trim and grill?
navynuke
Post by navynuke »
I still have the stock grill, but its broken, the brush guard twisted back into it. I also have the trim from around the grill.
What trim are you looking for, I may have it, although most of the interior trim is back in the truck.
navynuke wrote:I still have the stock grill, but its broken, the brush guard twisted back into it. I also have the trim from around the grill.
I need a stock grill and I want to send a piece of the grill surround and exterior fender trim to powder coat as a test.
navynuke
Post by navynuke »
I still have all of the trim, some of it is straight, some is not, but if you want it, come and pick it up. Since I don't need it anymore. Can you get price breaks on gear sets? maybe work out a trade since I'll be ordering gears and a yukon grizzly locker for the 9" rearend in the next week or two.
navynuke
Post by navynuke »
The 9inch is going in. Yukon gears and a grizzly locker. Just waiting on parts now.
Summit is cheaper than anyone can compete with. I usually buy what I can from there.
navynuke
Post by navynuke »
Parts should be here today, got them through a local offroad shop I deal with here in town. He is helping me with enough stuff off and on, I'll pay him more for all the stuff he helps me with and doesn't charge me for.
navynuke
Post by navynuke »
started install today, all was going well, except the locating stud on the driver side leaf spring looks a bit worse for wear
I've broke a few of those. Not too bad to replace though. Could be worse. You couldve had your leafsprings come off and snap a drive line like I did.
navynuke
Post by navynuke »
Back on the road. a bit of clicking or popping around corners, I believe its the yukon grizzly locker, as straight line is fine. I will be rechecking everything when I get home from class.
picked up some motor parts for the new motor I'm building,
  • new Gt40P heads
  • BBK shorty ceramic coated headers
  • high volume oil pump
Hoping to be able to leave tomorrow afternoon for KOH too.
navynuke
Post by navynuke »
After beating on this thing out at the King of the Hammers race, the yukon grizzly locker is working pretty well. acted up a little on a downhill curvy road coming home from the dump yesterday.
Adding mounts for my fire extinguisher and flashlights this week, as well as hopefully getting the wiring and control surface for my winch built up this week before going to the Battle for Primm this weekend.
navynuke
Post by navynuke »
Looks like I'm picking up some rear shocks for the bronco. Pair of fox 2.5" reservoir with 12 inch travel.
I know the valving is wrong, and I will need one of the upper mount setups for them.
What valving do you guys recommend, weight is about 5200 pounds empty, and superlift 4" lift springs.
Also what shock mount setups do you guys recommend, or should I put my own together?
Thanks guys
Ken
Fox are the longest shocks out there. You may have issues fitting 12" under the bed with those.
navynuke
Post by navynuke »
and they are probably not ideal for use if you go through the floor and up to the cage then.
I am open to suggestions then, the price on these was good, but if they will probably not work I'll pass on them.
and they are King, not Fox, makes em a little shorter.
this ad on RDC
http://www.race-dezert.com/cgi-bin/trad ... d&id=30948
