Mild DD 1982 F150 flareside build
Re: Mild DD 1982 F150 flareside build
Been there, done that stuffing a supercab on the U-Haul trailer that is a tad too short for it. Our trip was be from Hesperia at +/-45 MPH the whole way.
x 294.jpg (122.46 KiB) Viewed 2483 times
x 296.jpg (101.15 KiB) Viewed 2483 times
Oh, and this was the tow rig, so it's not just towing with the bronco - it's the load and weight distribution of that load on the trailer.
x 295.jpg (111.68 KiB) Viewed 2483 times
I swear I was going to lose it at one point. Super sketchy. I should have done that with the ramps and tie downs.
we almost did lose it on our trip. VERY scary. That was when we hit I think about 55 mph coming down a grade. Pucker moment for all of us in the truck for sure! Slow & steady after that...
Hopefully the resale on yours will be worth the effort though. Or you could just keep it for the longer wheel base to tow the next one - lol.
I have a problem.
1982 bronco, 351w, c6 trans, limited slip 9", bolt in axle front third member, full power and AC. Basically everything people want to start a great Prerunner build.
zachwabbit
Post by zachwabbit »
Looks so rad and retro haha and don't worry I have the same problem, just can't seem to get anything done in a timely manner..
Potato.
so I take it he texted you back...
Did you drive it to the house? If you say yes I'm gonna be REALLY jealous!
Yep, runs with a 351w and c6. Carb needs to be cleaned or choke needs work but once it's warm it runs great.
Tchajagos wrote:Image
I have a problem.
Sweet...if it had the sliding side windows it'd be a unicorn
Sent from my SAMSUNG-SM-N920A using Tapatalk
Been working all month on prepping this old race truck for norra.
It's a 1980 but had an ugly 87-91 front clip put on at some point. They wanted me to go down and chase with them for the race but apparently Norra is the same weekend as my wedding! Doh! Kind of bummed about that.
Plated my beams and added a little truss.
hollandermotorsports
Dude you get married on Saturday right? Go down Sunday super early a honey moon chasing through baja would be epic.
Looks great buddy.
hollandermotorsports wrote:Dude you get married on Saturday right? Go down Sunday super early a honey moon chasing through baja would be epic.
Looks great buddy.
I'd like to stay married for more than a day. ;)
Hahaha - smart man.
Got some parts back from powder coating. It's been so hot here, hard to be motivated to install anything in the heat.
Well. Thought I’d update. Installed a few things.
5/8” pivot bolts.
And she’s on her own weight now. Next on the list is to make a new engine cage cross bar. I guess these earlier frames are a little bit narrower than the solo cage was built for.
zachwabbit
Good for you man, glad to see it all coming together!
Potato.
Little update.
Made some extended shackles for a 3” wide spring.
Moved to her new location
Dropped the hangers.
As you can see the shackles didn’t want to work with these wider springs. At full droop the leaves were separating a lot and I wasn’t getting very much droop. The shackle was barely moving also.
So I moved the hanger back.
This gave me a lot more travel. The shackles can actually move and do their job now before the leaves start to separate.
