95 Black Bronco
95 Black Bronco
The stock tie rods deflect alot too, put your front end in the air and move your wheel back and forth, you would be surprised how much the tie rods move
95 Black Bronco
Did you delete your ABS module? The one that was located at the driver side frame rail ?
- rdcjuanb
Re: 95 Black Bronco
I don't want to look. HahaC H O wrote:The stock tie rods deflect alot too, put your front end in the air and move your wheel back and forth, you would be surprised how much the tie rods move
95 Black Bronco
Yes sir, Brian (cs drums) helped me do the wiring to bypass the abs. I replumbed all of the brakelines with stainless tube and -3 an fittingsAndy Jones wrote:Did you delete your ABS module? The one that was located at the driver side frame rail ?
95 Black Bronco
Do you have any pics of the brake lines Andrew? I want to do that but have no idea. I already removed all the wiring but the lines still run through the module.
95 Black Bronco
I think there are pics of them further back in the thread, from the master the fronts go to the tranny crossmember and T off a hardline runs down the inside of the radius arm.
95 Black Bronco
The only one I found was on top of the radius arm. What soft line did you use? Custom? And is the hard line double flared and then a standard inverted flare to -3 adapter? I'm new at this.
95 Black Bronco
I'm new at this too ! I'm gonna start tearing out all my ABS stuff this week.
Re: 95 Black Bronco
been a while since i have posted!
- IMG_0271.JPG (1.17 MiB) Viewed 2432 times
- IMG_0454.JPG (1.92 MiB) Viewed 2432 times
- Rustbucketracer
- Bronco Info: 1993 BRONCO, grocery getter
95 Black Bronco
Such a clean truck. Awesome job Andrew!
Re: 95 Black Bronco
I hate you...... That's all.
Re: 95 Black Bronco
That board looks rad Cho! Reminds me of a 5'6" Bing that I had awhile back.
Re: 95 Black Bronco
Tony I whole heartedly concur lol-- bad ass CHO ... simply bad ass!
Re: 95 Black Bronco
I just re read all 16 pages... Tony is right. Killer Bronco!
- Bronco Info: 1994 Bronco with aftermarket lift, BroncoAir bumpers
95 Black Bronco
Very Nice!
95 Black Bronco
Thanks guys! Going to be wrapping a couple loose ends here in the next week (steering, hood, limit straps) and than she will be dialed
95 Black Bronco
Finished up the front (for now) did big 5/8 wheel studs, limit straps, and single swing steering. All heims are 7/8 4130 FK, tie rods are 1.25" 4130 .375 wall drilled and tapped. Swinger and pitman arm tig welded 4130. Think I got all the buzz words in there!
the truck handles soo much better with the new steering set up. The ratio is sped up a little bit, has much better ackerman and very minimal bumpsteer on the pass side.
Re: 95 Black Bronco
Money shot!!
Re: 95 Black Bronco
Looks killer buddy.
Re: 95 Black Bronco
Looking awesome...... both of those rigs looking sweet!
