95 Black Bronco
C H O
Bronco Info: 1993 Lightning
95 Black Bronco
Post by C H O »
The stock tie rods deflect alot too, put your front end in the air and move your wheel back and forth, you would be surprised how much the tie rods move
95 Black Bronco
Did you delete your ABS module? The one that was located at the driver side frame rail ?
rdcjuanb
Re: 95 Black Bronco
Post by rdcjuanb »
C H O wrote:The stock tie rods deflect alot too, put your front end in the air and move your wheel back and forth, you would be surprised how much the tie rods move
I don't want to look. Haha
C H O
95 Black Bronco
Post by C H O »
Andy Jones wrote:Did you delete your ABS module? The one that was located at the driver side frame rail ?
Yes sir, Brian (cs drums) helped me do the wiring to bypass the abs. I replumbed all of the brakelines with stainless tube and -3 an fittings
birdco85
Bronco Info: 95 5.8 MAF E4OD
95 Black Bronco
Post by birdco85 »
Do you have any pics of the brake lines Andrew? I want to do that but have no idea. I already removed all the wiring but the lines still run through the module.
C H O
95 Black Bronco
Post by C H O »
I think there are pics of them further back in the thread, from the master the fronts go to the tranny crossmember and T off a hardline runs down the inside of the radius arm.
birdco85
95 Black Bronco
Post by birdco85 »
The only one I found was on top of the radius arm. What soft line did you use? Custom? And is the hard line double flared and then a standard inverted flare to -3 adapter? I'm new at this.
95 Black Bronco
I'm new at this too ! I'm gonna start tearing out all my ABS stuff this week.
C H O
Re: 95 Black Bronco
Post by C H O »
been a while since i have posted!
Rustbucketracer
Bronco Info: 1993 BRONCO, grocery getter
95 Black Bronco
Post by Rustbucketracer »
Such a clean truck. Awesome job Andrew!
Re: 95 Black Bronco
I hate you...... That's all.
nubreed71
Re: 95 Black Bronco
Post by nubreed71 »
That board looks rad Cho! Reminds me of a 5'6" Bing that I had awhile back.
Re: 95 Black Bronco
Tony I whole heartedly concur lol-- bad ass CHO ... simply bad ass!
Re: 95 Black Bronco
I just re read all 16 pages... Tony is right. Killer Bronco!
PaleRider
95 Black Bronco
Post by PaleRider »
Very Nice!
C H O
95 Black Bronco
Post by C H O »
Thanks guys! Going to be wrapping a couple loose ends here in the next week (steering, hood, limit straps) and than she will be dialed
C H O
95 Black Bronco
Post by C H O »
Finished up the front (for now) did big 5/8 wheel studs, limit straps, and single swing steering. All heims are 7/8 4130 FK, tie rods are 1.25" 4130 .375 wall drilled and tapped. Swinger and pitman arm tig welded 4130. Think I got all the buzz words in there! Image the truck handles soo much better with the new steering set up. The ratio is sped up a little bit, has much better ackerman and very minimal bumpsteer on the pass side. ImageImageImageImageImageImageImage
Re: 95 Black Bronco
Money shot!!
hollandermotorsports
Re: 95 Black Bronco
Looks killer buddy.
Re: 95 Black Bronco
Looking awesome...... both of those rigs looking sweet!
