Fuse panel under hood bracket
Has anybody made a nice mount for the odd shaped fuse box on the driver side fender who went full tubular up front? I need some ideas.
- apache41
- Bronco Info: 1995 Ford Bronco Solo Coilover front, Deaver Rear with Solo under bed shock bracket and hanger relo
Re: Fuse panel under hood bracket
Not sure about "nice" but here is what I came up with so far. Autofab tube fender mount to Solo engine cage. Still working on the details.
- 20140819_175532.jpg (235.49 KiB) Viewed 1034 times
Where did you pass bolts thru the fuse box?
I did a quick edit on his pic.the red arrow shows the nuts from the fusebox studs
- image.jpg (203.05 KiB) Viewed 1018 times
Chopped and cropped but here's what I did.
- image.jpg (39.65 KiB) Viewed 1016 times
my fuse box doesn't have studs. Its an odd shaped piece of plastic. Did you keep the metal tray it was clipped to and that's where the studs came from?
I think so, I'll have to look.
There is a metal tray that holds the fuse box.
I might have one if you need it, Kritter.
I'm giving mine to Kris.........Steve, I'll take the spare one for the future. Eventually I will need one but not anytime soon.
