Fuse panel under hood bracket
Post by shockseals.com »
Has anybody made a nice mount for the odd shaped fuse box on the driver side fender who went full tubular up front? I need some ideas.
apache41
Bronco Info: 1995 Ford Bronco Solo Coilover front, Deaver Rear with Solo under bed shock bracket and hanger relo
Re: Fuse panel under hood bracket
Post by apache41 »
Not sure about "nice" but here is what I came up with so far. Autofab tube fender mount to Solo engine cage. Still working on the details.
Where did you pass bolts thru the fuse box?
I did a quick edit on his pic.the red arrow shows the nuts from the fusebox studs
Chopped and cropped but here's what I did.
my fuse box doesn't have studs. Its an odd shaped piece of plastic. Did you keep the metal tray it was clipped to and that's where the studs came from?
I think so, I'll have to look.
There is a metal tray that holds the fuse box.
I might have one if you need it, Kritter.
I'm giving mine to Kris.........Steve, I'll take the spare one for the future. Eventually I will need one but not anytime soon.
Jbfab
Post by Jbfab »
Mines not great looking but functional.
