Rear Seat Options
- bajascott
- My belly is my best friend
Re: Bench seat vs. 2 seats in rear
http://www.gofastbroncos.com/forum/view ... f=26&t=248
i make them and the brackets are rivoted to the top with large rivots (included with the brackets)
The rear floor is elevated so with the rear seats right behind the drive and passenger the rear occupants can see just like the front passengers. I have heard zero complaints and actually shocked seasoned racers who doubted hte back seats as being functional for prerunning.Wood wrote:It is just 40" wide which will keep heads away from the diagonal cage bars and provide a better view out the windshield since that's narrower than front seats. I want to make it easily removable and I will probably ly have to add a removable cross bar for shoulder belts too.
There is already a removable bar behind front seats.
Frontrunner54
Suppose its kinda stupid... but growing up, we always faced the back.
I want to build my rear PRP bench to be removable, but reversible as well.
Found.Off.Road.Dominating.
Dezertbronco
- Bronco Info: 1990 Bronco EB
Seat bad bench mounting
I'm looking for suspension seat and bench mounting ideas, can you guys post up your favorites?
Re: Seat bad bench mounting
This is what ive got planned. My favorite set up ive seen so far.
- uploadfromtaptalk1403096919239.jpg (44.05 KiB) Viewed 906 times
- uploadfromtaptalk1403096903602.jpg (98.6 KiB) Viewed 906 times
- uploadfromtaptalk1403096886907.jpg (71.86 KiB) Viewed 906 times
Dezertbronco
I like it, I'm contemplating installing the front drivers seat on a 6 way electric mount so I can get sone extra leg room and gilt for those long trips. My bench is only 42" wide but I will upgrade it later.
Dezertbronco
Here's mine:
- image.jpg (201.23 KiB) Viewed 883 times
- image.jpg (184.87 KiB) Viewed 883 times
Dezertbronco
That's sweet, any photos with the bench mounted?
Ill snap one tonight if I get time. Basically I machined 4 1/2-13 bungs and welded them into the tubes ( 1 1/2 .120 wall) this puts the tabs 3/4 of an inch off the floor. It was the lowest way I could think of to maintain head room. With me in the back seat it leaves me 10-12 inches headroom to the cage. I'm about 6ft.
I was looking at that pics of the base earlier Robert & thinking "how the heck does he mount the inner tabs of the seats???? Totally forgot this was for a bench & not 2 individual seats so there's only 4 tabs total
Yessir you got it Steve.
Dezertbronco
Has anyone installed pump style lumbar in seats?
Contemplating heaters as well.
Your thoughts?
Your thoughts?
I ran both in my prp seats. The lumbars were out of my Eddie Bauer seats and I bought the doorman heater kits. Works really well.
