What's up dudes ... I'm new here
Marinrockstar7
- Bronco Info: 89 ford bronco full size
89 bronco 4" lift 35" grabbers with double standards method
I'm looking to hit the trails with you guys
When is the next trip ?
- Badass bronco !!!
- IMG_4660.JPG (725.93 KiB) Viewed 3918 times
Re: What's up dudes ... I'm new here
Welcome!! Whenever you want to plan one!
Where about are you? I'm in lakeside.
Marinrockstar7
el cajon
Marinrockstar7
do you know any good trails near
eoffroader
Welcome I'm in el Cajon as well I'd be down to head out but the truck needs some work first
Marinrockstar7
I'm down anytime on the weekends
- BabyJake
- Bronco Info: 1988 Ford Bronco V8 5.8L 4x4 Eddie Bower
Welcome!
I'm game !! Engine will be done in 7 days or so.
- THEJESUS
- Bronco Info: 1992 BRONCO XLT
Welcome!
Marinrockstar7
Let's plan a bronco meet east county
- zachwabbit
Marinrockstar7
Bronco meet up
Let's do it
Marinrockstar7
Let's do it
- IMG_7090.JPG (39.51 KiB) Viewed 3839 times
eoffroader
I'm down
- BabyJake
Wouldddddd
Marinrockstar7
Simone knows how the underhood light works ??
I replace the light already but still doesn't works
- zachwabbit
Check the wiring where it runs into the socket for the bulb, sometimes comes loose there. Other than that, a fuse maybe but I remember right the underhood light is on the same fuse as some other lights so you'd be seeing issues elsewhere too if it's that, correct me if I'm wrong
Potato.
