What's up dudes ... I'm new here
Well? Who are you?
Marinrockstar7
Bronco Info: 89 ford bronco full size
Post by Marinrockstar7 »
89 bronco 4" lift 35" grabbers with double standards method
I'm looking to hit the trails with you guys
When is the next trip ?
Badass bronco !!!
Badass bronco !!!
Re: What's up dudes ... I'm new here
Welcome!! Whenever you want to plan one!
birdco85
Bronco Info: 95 5.8 MAF E4OD
Post by birdco85 »
Where about are you? I'm in lakeside.
Marinrockstar7
el cajon
Marinrockstar7
do you know any good trails near
eoffroader
Bronco Info: 1994 bronco 4.5 beams bilstein c/o behind the beam rad arms 456 front and rear f53 deavers blue inte
Post by eoffroader »
Welcome I'm in el Cajon as well I'd be down to head out but the truck needs some work first
Marinrockstar7
I'm down anytime on the weekends
BabyJake
Bronco Info: 1988 Ford Bronco V8 5.8L 4x4 Eddie Bower
Post by BabyJake »
Welcome!
cwrisley
Post by cwrisley »
Welcome. I'm also in El Cajon. We seriously need an East County Bronco meet!
Sent from my SM-G928V using Tapatalk
Bajaluv
Post by Bajaluv »
I'm game !! Engine will be done in 7 days or so.
THEJESUS
Bronco Info: 1992 BRONCO XLT
Post by THEJESUS »
Welcome!
Marinrockstar7
Let's plan a bronco meet east county
cwrisley
Post by cwrisley »
Just throwing out a date/idea, but how's Friday Sept 8th at Eastbound Bar and Grill? Park in the dirt lot across the street so we don't impact parking too much. 6:30 or 7 till whenever?!
zachwabbit
Post by zachwabbit »
Welcome dude! I'll try and get work off, I'm down
Potato.
Marinrockstar7
Bronco meet up
Let's do it
Marinrockstar7
Let's do it
eoffroader
I'm down
BabyJake
Post by BabyJake »
Wouldddddd
Marinrockstar7
Simone knows how the underhood light works ??
I replace the light already but still doesn't works
zachwabbit
Check the wiring where it runs into the socket for the bulb, sometimes comes loose there. Other than that, a fuse maybe but I remember right the underhood light is on the same fuse as some other lights so you'd be seeing issues elsewhere too if it's that, correct me if I'm wrong
Potato.
