1990 go fast bronco “Eddie “
xjgiles_
Bronco Info: 1996 lariat bronco
Re: 1990 go fast bronco “Eddie “
Post by xjgiles_ »
Wrightracing.net wrote:
xjgiles_ wrote:Axle is all welded up! Next it will be getting a back brace some mounts and figure out what I’m doing for hubs.
Nice, I have toyed with the idea of doing my own 9" full floater. I hope to get a new fixture table this next year and it would be perfect to keep everything straight while welding things together. I need more practice on my TIG welder, but hope to do it all with the TIG.
Did you use a alignment bar inside? I plan to use one if I do mine and I can turn the tube pucks to center the bar. I got the idea from the axle narrowing kit's I was seeing on Ebay.
I want 3.5" tubes and the end goal is 71" wms to wms to match my +3 per side front.
I have a ton of other work, before I get to the rear axle. I can run my current 9" that is 3" tubes and stock width with a truss I had Currie do new about 20+ year's ago.
David
Yes I used an alignment bar I have 6 pucks per side I believe. Im shooting for 74’’ to match my front width I have 3” .25 wall tubes on this one. It should be plenty strong for here in Michigan.
xjgiles_
Post by xjgiles_ »
Finally had some time to work on this again. Made motor mounts and got the ecu mounted and started wiring
xjgiles_
Post by xjgiles_ »
Picked up a few parts last night for $600 set of 4 coil overs and 4 bumps.Image
Next weekend I’m picking up a set of 48” trailing arms so I’m a few more parts
Closer to linking my bronco!
xjgiles_
Post by xjgiles_ »
Picked up my trailing arms last weekend Thursday I cleaned my barn and moved the bronco to the middle of the floor. I also started mocking up my link brackets on the frame side. This location should get me to about 112” wheel base.Image
xjgiles_
Post by xjgiles_ »
Well been picking away at this some lately.
I removed all the rear suspension still need to cut off the front hangers but the rear are goneImage
Cut a hole to figure out shock placement. I still need to buy a bypass yet.
I will end up notching the frame to get everything up higher but been waiting for weather to get colder so I could start working on this again.
xjgiles_
Post by xjgiles_ »
Well made some more progress on the rear axle using 14 bolt spindles and hubs I will weld up turn down and redrill to 5x5.5 to match the front
xjgiles_
Post by xjgiles_ »
Last night I decided to turn down the 14 bolt hubs and get them ready to be re drilled
xjgiles_
Post by xjgiles_ »
Last night I taught my son how to indicate the hub on center and we drilled the new bolt pattern in the hubs.Image
Solid lessons!
xjgiles_
Re: [emoji[emoji638][emoji639][emoji[emoji6[emoji640][emoji638]][emoji640][emoji640]][emoji[emoji6[emoji640][emoji638]][
Post by xjgiles_ »
Well I decided
Edited by Admin 'cause post was cra-cra... spam or Tapatalk issue?
GoFastBroncos.com
Post by GoFastBroncos.com »
Dang
xjgiles_
Post by xjgiles_ »
GoFastBroncos.com wrote: ↑
Fri Feb 07, 2025 12:53 pm
Dang
Thanks for cleaning that post up the last couple I did on tap a talk did that
xjgiles_
Post by xjgiles_ »
Pulled my Gen1 Coyote out and put a low mileage gen 2 in. The control pack is much easier for the gen 1 than gen2 I made some trans line adapters and got my cooler temporally hooked up. I also ran my fuel line to the front. I decided 35’s were too small and decided to sell them for 37’s…. I couldn’t find any good deals on nice used ones so I ended up with a set of 40’s. Been picking away at this along with my dads early Bronco prerunner we are finishing
xjgiles_
Post by xjgiles_ »
Haven’t updated this in a while. Been working on it a lot and have gotten a lot of things done. Aftermarket center section with 35 spline spool and 5.13 gears set up. Started my fast/ council started some bumpers rear shock mounts seat mounts trans crossmember picked up some 2.5x12 kings fir the front. Next I plan on tying the engine cage into the main cage. Currently waiting on my rear bypasses and exhaust kit to come in
Getting it done! Looks good.
xjgiles_
Post by xjgiles_ »
Just to get this up to date have done a ton of work it’s now painted with the exception of the rear fenders still waiting for those to come in. Has bypasses on all 4 corners exhaust is out the back. Runs and drives still waiting to finish a few more things but she’s almost done.
xjgiles_
Post by xjgiles_ »
xjgiles_ wrote: ↑
Thu May 29, 2025 12:24 pm
xjgiles_
Post by xjgiles_ »
Well this thing is up and running and working on tuning suspension
Nice! Hows it do so far? Does it need big shock changes or is it close?
xjgiles_
Post by xjgiles_ »
hobbyturnedobsession wrote: ↑
Sun Aug 10, 2025 6:00 am
I changed my front springs and it’s a lot better. Next I will be adding my spare tire carrier and probably be changing rear springs.
