Willie's.....1992
- funinthesun95
Re: Willie's.....1992
Bret's new rear end set up works very well.
He also added new in the cab anti dust shock covers. They cover the floor opening and run up the shock.
The Bronco now has King 3.0 coil-overs on all 4 corners with finned Res.
- keep your Cab dust free.JPG (82.2 KiB) Viewed 5985 times
- funinthesun95
This is the Bronco all loaded up for the Baja 500.....
- Baja 500 2016.JPG (69.68 KiB) Viewed 5985 times
- keenanduran1
Nice to meet you in the middle of no where and thanks for helping out when our called pulled into the pit. Your bronco looks great!
- funinthesun95
just a quick update bronco was sold.
4WPRusty
- Bronco Info: 1992 Bronco. Caged, Linked and Loud
Update: this build is now in my hands. I plan to do some updating. New seats, new 37” tires and forged wheels, new Rigid lighting and fiberglass hood.
- EFECFC4F-7CC6-4B30-BE5E-D037101792D2.jpeg (625.53 KiB) Viewed 5604 times
- Bftank
- Bronco Info: 1996 bronco 6 inch dick cepek front, deavers in the rear
looks good!
4WPRusty
Updated the lighting today. Old school meets new school. Rigid Adapt (GPS) controlled lighting.
- E98C8D04-D09B-4545-B2D0-A8248A858A53.jpeg (399.02 KiB) Viewed 5487 times
- funinthesun95
looks great.....we need to ask SteveG for a name change......you need to make this your own now!
4WPRusty
A little update. I will also start a new thread.
New Baja Fiber Hood
New Baja Fiber Hood
- 37427D1E-86A9-4B87-8942-E299EC43AA79.jpeg (314.22 KiB) Viewed 5384 times
- DE658C87-60C0-484C-9BAB-C3BB5AC95445.jpeg (416.68 KiB) Viewed 5384 times
4WPRusty
New Raceline Avengers 2’s. Updated design and 38” Falken R-Spec tires.
- CF7585E7-AFBD-4DA4-8E39-BCEE3F239979.jpeg (325.75 KiB) Viewed 5384 times
- EFC516FC-0B18-4FB6-9845-94576D438016.jpeg (332.11 KiB) Viewed 5384 times
- 95E5129D-3C0A-490C-BF92-91BD1E708FAE.jpeg (451.28 KiB) Viewed 5384 times
- Andy Jones
- Bronco Info: In the Works!
Willie's.....1992
Looks AWESOME!!!
- funinthesun95
4WPRusty
First off I have contacted the admin to ask about changing the thread title.
I have made some updates.
1. Added PRP seats.
2. Removed the CD player and replaced with Bluetooth controller and IPad to run audio, video and NAV.
3. Added factory spare tire mount. Still have to beef it up to carry the load.
4. Changed up the tires and wheels for work.
5. I made a bracket that holds a Rigid Chase light as a 3rd brake light.
1. Added PRP seats.
- 07981562-51F6-4CEB-9E84-069959A1B2FD.jpeg (28.5 KiB) Viewed 4630 times
- 44896BF2-E1AD-4D84-AA73-DE039FF1F1DD.jpeg (17.62 KiB) Viewed 4630 times
- 7AD1246E-3E08-4693-B128-E944E6369D75.jpeg (36.37 KiB) Viewed 4630 times
- 66FDF9E8-0EB2-475A-96D9-42F25215B39E.jpeg (39.51 KiB) Viewed 4630 times
- E5A94E02-AF19-4C5D-9604-A01B45E5DE5A.jpeg (26.57 KiB) Viewed 4630 times
- 45629F5F-F7B6-4A15-91B3-9FEC7A270588.jpeg (20.16 KiB) Viewed 4630 times
That brake light idea is sweet!
- THEJESUS
- Bronco Info: 1992 BRONCO XLT
Your Bronco is badass!!
4WPRusty
Time to remove the rear shocks and 3rd member.
- D45439CB-BCF6-4C1B-B5F3-96CC108B1F7F.jpeg (343.41 KiB) Viewed 4552 times
4WPRusty
Thank you.THEJESUS wrote:Your Bronco is badass!!
Pickuptrucker
- Bronco Info: 1982 c6, 9" gears, lockers,
Brake light idea is great!
4WPRusty
I was having some issues with the sway bar. I ended up removing it. The splines were flat on the passenger side. Time for an upgrade.
- 7654264C-AF1F-43A3-86F5-AD4BE47C9AE6.jpeg (331.72 KiB) Viewed 4511 times
4WPRusty
3rd brake light brackets coming soon. I need to draw to have the parts drawn up sent to the laser cutter. DM if interested in one.
- 60CCA920-DF41-4BE9-966A-55478501AF86.jpeg (84.69 KiB) Viewed 4511 times
- AC1A66FE-6B25-49C8-B101-4B26E8AF57A5.jpeg (64.56 KiB) Viewed 4511 times
- 31FECE00-A853-4C19-872A-81BA1A22E799.jpeg (46.22 KiB) Viewed 4511 times
- 1F2961C4-C38B-4A67-A659-9CE646C2D485.jpeg (55.97 KiB) Viewed 4511 times
- 7A6E0B7D-D232-4BF0-A8F1-895AB66B42F6.jpeg (75.88 KiB) Viewed 4511 times
- A26FD4D7-169F-4A2C-8C4B-19F1F7119E97.jpeg (73.7 KiB) Viewed 4511 times
