Willie's.....1992
Re: Willie's.....1992
Bret's new rear end set up works very well.
He also added new in the cab anti dust shock covers. They cover the floor opening and run up the shock.
The Bronco now has King 3.0 coil-overs on all 4 corners with finned Res.
keep your Cab dust free.JPG (82.2 KiB) Viewed 5958 times
This is the Bronco all loaded up for the Baja 500.....
Baja 500 2016.JPG (69.68 KiB) Viewed 5958 times
keenanduran1
Post by keenanduran1 »
Nice to meet you in the middle of no where and thanks for helping out when our called pulled into the pit. Your bronco looks great!
just a quick update bronco was sold.
4WPRusty
Post by 4WPRusty »
Update: this build is now in my hands. I plan to do some updating. New seats, new 37” tires and forged wheels, new Rigid lighting and fiberglass hood.
Bftank
Bronco Info: 1996 bronco 6 inch dick cepek front, deavers in the rear
Post by Bftank »
looks good!
@outdoorexplorationgear on Instagram, focused on Krustythebronco, building a towrig, creating a prerunner/rockcrawler business.
4WPRusty
Post by 4WPRusty »
Updated the lighting today. Old school meets new school. Rigid Adapt (GPS) controlled lighting.
looks great.....we need to ask SteveG for a name change......you need to make this your own now!
4WPRusty
Post by 4WPRusty »
A little update. I will also start a new thread.
New Baja Fiber Hood
4WPRusty
Post by 4WPRusty »
New Raceline Avengers 2’s. Updated design and 38” Falken R-Spec tires.
Willie's.....1992
Looks AWESOME!!!
agree
4WPRusty
Post by 4WPRusty »
First off I have contacted the admin to ask about changing the thread title.
I have made some updates.
1. Added PRP seats.
2. Removed the CD player and replaced with Bluetooth controller and IPad to run audio, video and NAV.
3. Added factory spare tire mount. Still have to beef it up to carry the load.
4. Changed up the tires and wheels for work.
5. I made a bracket that holds a Rigid Chase light as a 3rd brake light.
biggiek
Bronco Info: 92 Ford Bronco
Post by biggiek »
That brake light idea is sweet!
THEJESUS
Bronco Info: 1992 BRONCO XLT
Post by THEJESUS »
Your Bronco is badass!!
4WPRusty
Post by 4WPRusty »
Time to remove the rear shocks and 3rd member.
4WPRusty
Post by 4WPRusty »
THEJESUS wrote:Your Bronco is badass!!
Thank you.
Pickuptrucker
Post by Pickuptrucker »
Brake light idea is great!
4WPRusty
Post by 4WPRusty »
I was having some issues with the sway bar. I ended up removing it. The splines were flat on the passenger side. Time for an upgrade.
4WPRusty
Post by 4WPRusty »
3rd brake light brackets coming soon. I need to draw to have the parts drawn up sent to the laser cutter. DM if interested in one.
