Guess my hp/tq its Dyno day!
Current numbers after Edelbrock Performer intake, Performer cylinder heads, headers, a set of Crane Cams 1.7 ratio rocker arms.
166 hp at 3,750 rpm
256 lb-ft at 3,200 rpm
Since that last dyno pull the E303 cam,bassani y pipe and full 3" exhaust has been added,Intake is stock with an AEM dryflow filter.
Im hoping for 230+hp 300+tq after today. My appointment on the dynojet is at 2pm ill post up the results tonight.
Whoevers guess is closest wins 2 petfified cheetos i found in the passenger side map pocket!
GO!
166 hp at 3,750 rpm
GO!
Re: Guess my hp/tq its Dyno day!
179 hp
291 torque
291 torque
207 hp
311 torque
311 torque
187 hp
298 torque
298 torque
- Agui-E7TE
175HP
275 Torque
On Nitrous.. (50 shot)
210HP
320 Torque
275 Torque
210HP
320 Torque
- Silverslk
Bad idea Ryan... Dyno pulls are always heart breakers.... You never get what you're hoping for. I've dyno'd my gti, Benz, gsxr750, zx9 and waiting to dyno zx10 after the valve adjust/service. I think you're hope is high for just a cam and exhaust addition. Hope I'm wrong.
I'm guessing between Steve and Tony...... Maybe
183hp
275tq
183hp
275tq
- guard
195 hp
285 lb-ft
285 lb-ft
Oh i know its wishfull thinking. Ill be happy for it to finally be tuned...
My thought is the cam can really bring the previous enhancements some life. Valves have to be open to flow. Still pulling for the bigger numbers Ryan.
- ESHALLBETTER
Put on stock tires, it'll add horsepower.
192hp
269 ft lbs tQ
269 ft lbs tQ
- Silverslk
Hell yeahESHALLBETTER wrote:Put on stock tires, it'll add horsepower.
- Silverslk
I figured as much Brian. I was thinking same but tried to account for loss of torque with 3" exhaust and added hp. My thoughts are the 303 will add more hp than torque with his current setup.yikes wrote:My thought is the cam can really bring the previous enhancements some life. Valves have to be open to flow. Still pulling for the bigger numbers Ryan.
Smart Alex
- Bronco Info: 1991 351. lightweight special
201 hp
310 tq
Best of luck!
310 tq
Best of luck!
Single 3" exhuast does not flow enough to reduce torque.Silverslk wrote:I was thinking same but tried to account for loss of torque with 3" exhaust and added hp.
Here we go!
- uploadfromtaptalk1391287223432.jpg (47.41 KiB) Viewed 4726 times
Drum roll please!!!
My GT40 302 put down 220hp 232ft/lbs torque with a holly 750 4 barrel carb....
I personally think once you put some 24# injectors in it and tune it you will easily see 220-230hp or maybe more.... I think its gonna starve gor fuel with the stock injectors
First pull pre tune and no clear winners from previous guesses...
AFR was tits all the way to redline with stock injectors.
