- BajaF250
- Bronco Info: 1982 Ford F250
'82 F250, D44HD front, D70 rear, roller EFI Lightning 351 transplant, coilover front, nationals rear, caged... 18" front and rear, sway-a-way all the way around.
**edit** resize pictures
- (9A) front view driveway.jpg (109.6 KiB) Viewed 45253 times
- (8A) right side view, driveway.jpg (109.77 KiB) Viewed 45253 times
- (7)%20PC060040.JPG (41.31 KiB) Viewed 45253 times
- (5a) summit w Rick 2.jpg (123.83 KiB) Viewed 45253 times
Re: BajaF250
That is a bad ass looking rig! I like it. I spy with my eye Autofab drop down hood and stock width front glass as well! Very nicely done.
Can we get some more pics.... interior cage pics, etc
Re: BajaF250
Very nice!
- BajaF250
Re: BajaF250
Great eye! Autofab drop down hood, glass stock width fenders with 3" higher wheel arches to fit the 35" and uptravel. Alum panel fender wells to keep the stuff out of the engine.
**edit, resize pictures (3690)**
- (17a) cab cage progress.jpg (104.75 KiB) Viewed 45253 times
- (15a) engine bay cage.jpg (127.33 KiB) Viewed 45253 times
- (14a) bed cage progress.jpg (106.87 KiB) Viewed 45253 times
- BajaF250
Re: BajaF250
Some more pics of the cab... cab out of paint and then put back together.
- (10A) PB152702.jpg (117.08 KiB) Viewed 45253 times
- (18a) cab cage.jpg (103.54 KiB) Viewed 45253 times
Re: BajaF250
That thing is nice!
Have you ever had problems with any of the D44HD knuckles, bearings, or spindles?
Dust
Re: BajaF250
WOW!
We really need a Beer Icon...
If there was one I'd give ya 6!
- BajaF250
Re: BajaF250
Never had any problems with the knuckles or axles. I busted a u-joint on the passenger side of the D44HD once, but that was directly due to the fact that the mech that I let work on the front end forgot to put the inner race on the right side output differential axle bearing. (I don't let folks work on my stuff anymore!)
Re: BajaF250
That's nice to know. I'm using the same stuff for my Crew Cab but for a 2wd setup. I was originally looking for a D50 setup but the beams I found to cut up ended being D44HD.BajaF250 wrote:Never had any problems with the knuckles or axles. I busted a u-joint on the passenger side of the D44HD once, but that was directly due to the fact that the mech that I let work on the front end forgot to put the inner race on the right side output differential axle bearing. (I don't let folks work on my stuff anymore!)
Re: BajaF250
Rumor also has it your on the new BFG KM2s now as well as a shell..... so how about more pics!
- BajaF250
Re: BajaF250
The only pic I have with the new KM2s is the pic Yikes posted. I'd put the new tires on and then had the front end painted just before this years 500, I literally picked the truck up from the painters the day before Tech and Contingency.
- '10 SF250.jpg (62.86 KiB) Viewed 45186 times
- '10 baja 500 contingency.jpg (68.11 KiB) Viewed 48766 times
Re: BajaF250
Now that's an awesome shot!
- BajaF250
Re: BajaF250
Thanks Brian, couldn't have done it without you!
- BajaF250
Re: BajaF250
I missed this one... the bed...
- (11a) caged bed.jpg (139.63 KiB) Viewed 45185 times
Re: BajaF250
Are those 18" SAWs? How much travel does that thing have in the back?
- whatdyisit
Re: BajaF250
Awesome truck.
I might be missing something but it looks like it would be a pain in the ass to get the spares out.
- BajaF250
Re: BajaF250
Actually, the spares are exceptionally easy to get in and out. Once the center section is loosened (only a couple of turns), the threaded portion comes out (it's on a hook tied into the cage bar), then I just tilt the tire and roll it out. Very easy. I'm pretty pleased with the way it all turned out. I also reinforced the bed beneath the tire to suppor the weight as I'm beating around off road. The reinvorcement also ties the tool box to the bed so none of it sits directly on the bed skin. Then, it was all Line-X'd... turned out very well and I'm happy with the functionality.
- BajaF250
Re: BajaF250
philofab wrote:Are those 18" SAWs? How much travel does that thing have in the back?
It has a full 18" of travel, but I limited the bump by about ½"
Re: BajaF250
Wow, very nicely done!! Now I want a Pick Up....
Question for you.. where did you get the shock boot I see on your rear shocks?
Re: BajaF250
Haha! Actually I was talking about the shot above it....100mph in the silt. Woohooo!BajaF250 wrote:Thanks Brian, couldn't have done it without you!
