96 Bronco - Project "Cheryl"
Take Ryan to box canyon if the rivers running.
Yep thats the one--- its dry as all hell right now-- its not tough on parts and its pretty fun-- best part if you blow something up-- its not too far from help
My grand parents owned a dry cleaners in wickenburg for 15+ years. I know that area well. Goldrushdays is always a blast too. Nothing beats Shriners doing wheelies on vw trikes.
I was wondering how in the hell you knew about Wickenburg ...Lol!!!
My bronco is down till maybe tuesday when the new computer shows up. I know the area you are talking about well. In my sand drag days on the DS650 we ueed to go out there under the bridge off I10
- Silverslk
Wickenburg is off the 60 toward Aguila..... not the 10 Ryan.RyanDS650X wrote:My bronco is down till maybe tuesday when the new computer shows up. I know the area you are talking about well. In my sand drag days on the DS650 we ueed to go out there under the bridge off I10
How in the hell do you CA guys know about the WB??
He went to high school there.
The hasayampa river bed goes a looooong way, Andy. Back when Whiplash off road racing had a race in wickenberg we preran all around that town. Id go back for a fun run with a local for sure!
- Silverslk
Unless you can tell me about the Salome 100.... don't say "back when" hahahahahaha
What are "thing old guys say" for $1000. Haha you got me beat.Silverslk wrote:Unless you can tell me about the Salome 100.... don't say "back when" hahahahahaha
- Silverslk
Your back when goes to the early 2000's.... mine goes back to the 80's hahahaRyanDS650X wrote:What are "thing old guys say" for $1000. Haha you got me beat.Silverslk wrote:Unless you can tell me about the Salome 100.... don't say "back when" hahahahahaha
Graduated Salome High School 1991 !! Take that you wipper snapper!!!
shit thats not old-- I graduated HS in 1993! Ryan-- get that bronco running and bring it to the WB!!!! btw-- are you getting a stock computer or a juiced up one??
Stock for now
Ball Joint Bling!!
Got some new ball joint bling-- chicks dig "gold" ball joints
. I am hoping the Raybestos premiums hold up to the TTB.
- image.jpg (97.25 KiB) Viewed 1151 times
Radius Arm Frame Brackets
Here are my radius arm frame brackets.
- image.jpg (109.58 KiB) Viewed 1142 times
- image.jpg (102.99 KiB) Viewed 1142 times
- image.jpg (92.48 KiB) Viewed 1142 times
- image.jpg (107.75 KiB) Viewed 1142 times
Nice! Get er done!
Rear Shocks Mounts
Rear shock mounts and the rear limit strap mounts
- Rear Limit Strap Mount.JPG (107.37 KiB) Viewed 1084 times
- Rear Shock Mounts3.JPG (120.8 KiB) Viewed 1084 times
- Rear Shock Mounts2.JPG (105.07 KiB) Viewed 1084 times
- Rear Shock Mounts1.JPG (112.65 KiB) Viewed 1084 times
Rear Leaf Spring Drop Hangers
Here are the rear leaf spring drop hangers that I built. Hopefully these get me 3" lift on the rear but I dont want to spend the cash on the leafs at this point. In the future I want to run longer shackles anyway. Just made out of some 1/8" plate and some 1/4" angle iron. The Kel-fab units are so sexy and probably will get as set of those at some point. If the lift for some reason is sits too tall the beauty here is I can just just build longer shackles to lower the rear end. Hopefully this all works out .... hopefully
- Rear Drop Hanger1.JPG (122.61 KiB) Viewed 1079 times
- Rear Drop Hanger2.JPG (126.65 KiB) Viewed 1079 times
- Rear Drop Hanger3.JPG (132.08 KiB) Viewed 1079 times
- Rear Drop Hanger4.JPG (130.42 KiB) Viewed 1079 times
Re: Rear Shocks Mounts
VintageIronFab wrote:Rear shock mounts and the rear limit strap mounts
Any plans to reinforce that rear shock mount once mounted?? I had my first mount built like this and it failed pretty quickly. A lot of load on that center disconnect. Just a thought.........
