Josh aka greaslifes 86
Re: Josh aka greaslifes 86
Nice job guys its coming together nicely.
greaslife
Thanks man I appreciate it
Love the look of the truss!!
Very nice.
Mojo
back on the ground, NICE!!! Good work guys....
Hell all I did was help him fill the diff and a few other things. He did all the work. Gears came out kitchen. Its a totally different bronco that's for sure.
Spell check strikes again Randy!
Glad to see the thing back on it's feet though!
Damnit... Bitchen not kitchen....
Hey Josh-- do you recall what size tubing you used to sleeve those axles?
greaslife
Not off the top of my head. I'll get back too you tomorrow when I get home from work.
- 93Broncobuff
Sick bro!!!!!!
thanks!
greaslife
I have driven it too work the last 2 day. Can believe how much easer it is too get going from a stop. Best mod I have done as of now. Now too find a cheep 5.0 too start rebuilding I think a stroker is up next.
greaslife
Shit my bad give me a coupple I'll get that for you.VintageIronFab wrote:thanks!
Proof he doesn't just doesn't get under it.
- uploadfromtaptalk1390248948020.jpg (88.17 KiB) Viewed 1230 times
- 93Broncobuff
Hshahhahahah nice randy.
greaslife
Took it too the race last weekend and noticed some engine problems. So after thinking and talking with people I have decided its time for a new engine. Going too pick up Randy's 351 and go through before I install it. I have been looking at cams and intakes along with other mods and decided f it. Keep it stock and reliable. I haven't talked my self out of ratio rockers or gp40 if the heads are f'ed once I tare them down. What's your thoughts
I am a fan of stock...... just my two cents.
Flat top pistons, mild cam and gt40 heads, smog headers and call it done.
Gt40 heads aren't smog legal. A set of Afr heads will be better smog legal and if found can be had for the same price as a set of gt40s after a rebuild. Also stock can and 1.7 roller rockers will do a hell of a lot along with port matching the lower intake.
