Bilstein 9100 and 9300 for sale
- baja-chris
12" 9100 series 4-tube bypass shocks (2.5"), retail is $927 ea. $800/pr.
14" 9100 series coilover with dual rate kit (2.5"), retail is $567 each. $450/pr.
16" 9100 series coilover with dual rate kit (2.5"), retail is $567 each, $450/pr.
18" 9300 series Blackhawk 4-tube bypass (3.0"), retail is $2950 each. These are Blackwahk prototypes with steel cans instead of aluminum but same pistons, resevoirs, bypass valves). $1500/pr.
4" air bumps (2"), retail is $170 ea. $200/pr or free if you buy all the shocks.
PM if interested.
PM if interested.
- baja-chris
Re: Bilstein 9100 and 9300 for sale
Why is there no edit on the website? Blackwahk is kinda like Blackhawk if you are a dyslexic typist.
Smokin deal Chris.... you going King or Fox on the bronco?
- baja-chris
Truck ended up much heavier than expected so need stiffer springs and bigger shocks.tcm glx wrote:Smokin deal Chris.... you going King or Fox on the bronco?
Going with Fox all around. 4.0+2.5 in rear and 3.5+2.5 in front.
That's more shock that my last two class 8 trucks had.
The Bilstein package I'm taking off is more shock than my play bronco has.
Will make for a great setup for someone.
- RNR Baja
- Bronco Info: Black 94 for chasing
Chris, where are you located? I am interested in the 14" coilovers
- Silverslk
Damn Chris.... You're either a month late or a month early..... Too close to holiday for me.... Damn you. Ha ha
These will sell quick...
- 93Broncobuff
Il hop second in line for those coil overs(14")
Mojo
I'll jump into 3rd spot on those 14" coilovers, cause you never know!!!
Mojo
I'll take the 12" bypass's?
- RNR Baja
Still interested in the coil overs
Sent you a PM Chris
Thanks
Sent you a PM Chris
Thanks
jonnyamerica
- Bronco Info: 1994 white XL Bronco
I would like to throw my hat in the ring for both the 16'' coilovers and the 18'' bypasses. sending PM now
- baja-chris
All of them gone now. I gave preference to guys who wanted more than one pair to make a complete setup for one end of the car. Thanks for all the inquiries.
Mojo
Thanks Chris
jonnyamerica
Muchos gracias Chris! One step closer on the build.
