Top Question
- Rg1Baja
- Bronco Info: 1992 Ford Bronco, 5.0, 4x4, STOCK
Top Question
What year hard top will fit on a 93? Is it just 92-96? Or will an 89-90 work as well?
Desertbatteries.com Dirtfreeks.com Odysseyfactory.com BFG.com
Re: Top Question
It will work.Rg1Baja wrote:What year hard top will fit on a 93? Is it just 92-96? Or will an 89-90 work as well?
- Bronco Broker
Re: Top Question
Technically 80-96. What you will lose if you do not use 92-96 is the third brake light and the interior rear shoulder seat belts. If you don't need either of those two you could pretty much use any year from 1980- 1996.Rg1Baja wrote:What year hard top will fit on a 93? Is it just 92-96? Or will an 89-90 work as well?
Re: Top Question
I think the 78-79 ones will even work. The tailgate is the same.
I had a 96 top on my 82. All I had to do was drill a 1/2 hole for a locating pin the newer tops have.
