Old school
Re: Old school
Well we took it out and it did pretty alright after i figured out i had two plug wires switched. Oops. Luckily my dad caught it right away and no big deal. The idle was high and a quick adjustment to the dual carb linkage fixed that. All in all it did real well and after bringing it home and cleaning the idle jets it fires right up and doesnt pop at all. We found out real fast that the harnesses need a submarine belt. Im doing some cleaning because frankly you couldnt tell where on part ended and another began.
- uploadfromtaptalk1385789756729.jpg (58.14 KiB) Viewed 1273 times
greaslife
Re: Old school
Sweet glad it all work out for you and you both had fun
Re: Old school
2 things, Generators suck and those fan shrouds suck. Granted, on something that light it may not ever matter.
Re: Old school
Im goin to do the alternator conversion and its never had overheating issues even though i hate chrome and it retains heat. Its difficult to change it when its worked for so long.
Re: Old school
A 36HP shroud with stock cylinder tins that have the deflectors intact. Also some super tins on the bottoms side=no cooking of the #3 cylinder.
It's amazing what people threw away off those motors becuase they didn't think it was neccasary. I have yet to see a set of heater flaps on a motor as they were usually the first thing thrown away in SoCal. It never gets cold here right?
Re: Old school
I picked up a wiring kit after looking at the rats nest behind the drivers seat and finding a bunch of loose wires still hot. Its an empi 6 fuse setup with a protected fuse case.
Re: Old school
The wiring kit
- uploadfromtaptalk1386206307551.jpg (90.01 KiB) Viewed 1206 times
- 93Broncobuff
Re: Old school
Have fun!!! Hahaha at least it will be done right.
Re: Old school
Yeah im shocked no one got zapped! The loose ends were near elbows.
greaslife
Re: Old school
A little custom work I knocked out today at work for yah.
switch box. don't pick on my welds I'm learning.
fuse block plate.
I know it's simple but that's what this is all about .
Re: Old school
Its perfect for thank you Josh! The fuse mount and switch panel can't be real elegant ill run out of room.
- Silverslk
Re: Old school
Thats cool as shit right there dude...
Re: Old school
I'm stoked. Its being mounted on the frontward tube topside for easy access. Also a huge thank you Josh for the additional goodies!
- 93Broncobuff
Re: Old school
Nice work josh!!!
Re: Old school
The gauge panel is in.
- uploadfromtaptalk1386383862499.jpg (85.37 KiB) Viewed 1095 times
- uploadfromtaptalk1386383839120.jpg (79.46 KiB) Viewed 1095 times
Re: Old school
Its good to have extra parts around. Ford solid state relay will work good for wiring.
- uploadfromtaptalk1386470620414.jpg (85.85 KiB) Viewed 1073 times
Re: Old school
Finished writing in the relay today. Starter and kill switch also wired in along with a generator kill switch and fuel pump. First day it fired off under new wiring. The relay is ready for a cover.
- uploadfromtaptalk1386559654259.jpg (78.01 KiB) Viewed 1053 times
- uploadfromtaptalk1386559626988.jpg (89.66 KiB) Viewed 1053 times
Re: Old school
Think I found the reason why the tail lights weren't workin. Also my partner in crime sleep in on the job again.
- uploadfromtaptalk1386563050088.jpg (62.65 KiB) Viewed 1042 times
Re: Old school
Liking the progress Randy! What steering wheel is that?
Re: Old school
My uncle gave it to me. Its a grant but I'm unsure the exact model. I can look it up if you'd like.
