Opinions please
stocker
Bronco Info: 1996-302-33s-e4od w/B&M-4.11s-aussie lockers f/r-leveling kit-m95 shocks-softtopper
Opinions please
Post by stocker »
I've always liked the prerunner type trucks and I take my Bronco to the dunes about twice a year but I'm sick of the rough ride and my tires rubbing on whoops and some jumps. I know a guy who's built about 25 prerunners and had him give me a quote for making the bronc a little smoother on the dunes but still daily drivable. His plans for the front are deaver coils, extended rad arms, small hoop for mounting king 2.5 resi shocks, extended bump stops and brake lines. Rear is deaver leafs, king 2.5s mounted under truck without cutting the bed up, bump stops and brake lines. He said it would come out to about 13 inches up front and 12 inches rear and a helluva lot smoother and only be lifted about 2 inches over stock.
Is anyone running a similar setup? How do you like it?
Re: Opinions please
It will be night and day over stock. I'm not running a similar set up but when you add 2.5's to anything it changes the equation greatly. You should enjoy the result. Good luck with your build.
Re: Opinions please
Rmc wrote:It will be night and day over stock. I'm not running a similar set up but when you add 2.5's to anything it changes the equation greatly. You should enjoy the result. Good luck with your build.
X2.
Re: Opinions please
Custom Deaver coils?? The off the shelf ons are 5.5" lift
stocker
Re: Opinions please
Post by stocker »
robertcrav wrote:Custom Deaver coils?? The off the shelf ons are 5.5" lift
I'm not exactly sure what he's doing for the coils, maybe it'll be higher than a few inches lift. The guy is good so I'm sure he'll figure somthing out, he just gave me a rough idea on what he could do to it for "cheap"
Re: Opinions please
Some say the front deaver 5.5 coils are too tall. You may want to look at the pro comp 4" springs.
-JD5353-
Re: Opinions please
Post by -JD5353- »
He could presumably be using the deaver coil with a custom coil bucket, to net the lift wanted and have the advantages of a longer coil.
Re: Opinions please
-JD5353- wrote:He could presumably be using the deaver coil with a custom coil bucket, to net the lift wanted and have the advantages of a longer coil.
Yep he could. Doesn't say above but that maybe an option.
Re: Opinions please
If you're going to build a shock hoop and spend the money on Kings in the front, ditch the coils and just run a coilover. Mounting and packaging it easier and there is more room for future additions with less rework.
-JD5353-
Re: Opinions please
Post by -JD5353- »
ESHALLBETTER wrote:If you're going to build a shock hoop and spend the money on Kings in the front, ditch the coils and just run a coilover. Mounting and packaging it easier and there is more room for future additions with less rework.
I agree with this. I was originally going to go coil bucket, but in the long run you end up about the same cost wise ether way, with adjustability , performance, and like mentioned above packaging and not reworking in the future on the side of the Coilovers.
stocker
Re: Opinions please
Post by stocker »
I talked to the guy and he said it would add about $600 onto the price but it'd be well worth it. I'll definitely be doing it when the time comes.
greaslife
Re: Opinions please
Post by greaslife »
stocker wrote:I've always liked the prerunner type trucks and I take my Bronco to the dunes about twice a year but I'm sick of the rough ride and my tires rubbing on whoops and some jumps. I know a guy who's built about 25 prerunners and had him give me a quote for making the bronc a little smoother on the dunes but still daily drivable. His plans for the front are deaver coils, extended rad arms, small hoop for mounting king 2.5 resi shocks, extended bump stops and brake lines. Rear is deaver leafs, king 2.5s mounted under truck without cutting the bed up, bump stops and brake lines. He said it would come out to about 13 inches up front and 12 inches rear and a helluva lot smoother and only be lifted about 2 inches over stock.
Look at my build I'm running almost same set up. The last time it was out it ran hard and felt like a caddy over a woop section. I went from PC 4 inc spring too the deavers nite and day diff. I extended my stock buckets too get her down around 4 inch lift.
stocker
Re: Opinions please
Post by stocker »
Look at my build I'm running almost same set up. The last time it was out it ran hard and felt like a caddy over a woop section. I went from PC 4 inc spring too the deavers nite and day diff. I extended my stock buckets too get her down around 4 inch lift.[/quote]
looks like you know how to use a welder haha the cage and extended beams will be later on in my build but the front hoops look good
Re: Opinions please
Chris, Would a progressive coil like your coils you use to have or still have on your coil over shocks be a benefit? Maybe a taller coil bucket with a progressive coil? Just a thought.
greaslife
Re: Opinions please
Post by greaslife »
That's all coming off. In the next 6-7 months. I have gotten better with the bender. Oh yah mite just bust out some tig.
