Ryan's '96
89bronco.jake
Bronco Info: 1989 bronco
Re: Ryan's '96
Post by 89bronco.jake »
ive looked at this thread a million times and somehow never managed to recognize those videos at sycamore. haha surprised i havent seen this thing driving around town!
Re: Ryan's '96
Ive seen you twice but i wasnt in the Bronco either time. Are you planning on going to the Baja HID trip in October? Its nice to have another gofast bronco in AZ. I think you, Gunit (Dave) and I are the only ones...
Re: Ryan's '96
Looking to heim my radius arms and push my beams foreward. Any sugestions on a high quality pivot box and heim combo??
Re: Ryan's '96
RyanDS650X wrote:Looking to heim my radius arms and push my beams foreward. Any sugestions on a high quality pivot box and heim combo??
Have checked out the Threat Motorsports Pivot boxes ? Good Quality stuff coming out of there.
Re: Ryan's '96
I've got a set of pivot boxes for sale fairly cheap. Quality is not bad at all.
In 1st post here:
http://www.gofastbroncos.com/forum/view ... 30&start=0
Kel Fab Creations
Bronco Info: 95 Bronco
Re: Ryan's '96
Post by Kel Fab Creations »
I sell these for 200 welded or 125 not welded.
Re: Ryan's '96
Kel Fab Creations wrote:I sell these for 200 welded or 125 not welded.
Such nice welds!
Re: Ryan's '96
Kelly's products are top notch too !!! I have plenty of his products on my rig.
Re: Ryan's '96
Those do look nice!
Re: Ryan's '96
Ryan,
What are you running for arms now? I wish I wasn't all the way out in Wickenburg-- I would love to see your truck!
Re: Ryan's '96
VintageIronFab wrote:Ryan,
All Autofab, the current mounts are bushings. Ive got a little tire to the rear of the front fenders action at full bump and im debating on weather to heim them and push the beam forward ( which in turn means i have to cut the stock bumper or do a tube bumper) ORRRRR sell my 9"wide APP's and go to a 7" Method. Dont tell anybody about me contemplating selling the APP's though, could start a fight!
Re: Ryan's '96
Wickenburg???? What the hell? Your location says Phoenix..... That's not the same place. Trust me, I went through high school in Salome
89bronco.jake
Re: Ryan's '96
if your still looking for heimed pivot box's i have a plasma cam, and a few sets drawn up already if your interested. and im close too! hah
oh and ive got some 17'' methods.... and i love the APP's..... just saying! haha
Re: Ryan's '96
In my quest to find my weird idle issue i went a little overboard...
Turns out i had a few issues that could have contributed to it.
1. Replaced the upper and lower intake manifold gaskets
2. found i was missing a bolt on the collector at the y pipe outlet pulling in outside air being fed to the O2's
3. the last O2 sensor plug harness and been resting on top of the cat and had successfully melted damn near all the way through the harness.
Found 1 motor mount completely broken and the the other pretty beat and bolts loose so those got replaced also.
Fixed the rear locker leak
new spark plugs, cap and rotor.
new steering gear box and 4" drop pitman arm
new alternator, idler pulled and 1 other pulley that was shot
water pump gasket
Ordered some coil spring retainers from Ballistic Fab so i can put my Deaver coils back on.
New front brake lines from Crown
fuel filer
oil change
Should be good for another few years haha. i planned on a few suspension upgrades but those will have to wait.
She might be ready for KOH 2014....
I hoped to get more done but a job change put some of the cool stuff i had in mind on the back burner.... such is life right?!
Re: Ryan's '96
RyanDS650X wrote:In my quest to find my weird idle issue i went a little overboard...
water pump gasket
fuel filer
oil change
Ryan,
That is awesome, are you going to be in town for KOH afterall? I can think of a good steakouse for dinner!!!!
Re: Ryan's '96
Cant say for certain just yet. What days are you going?
Re: Ryan's '96
Thursday night and Friday for race day.
Re: Ryan's '96
Deavers going back on. Used Balistic fab spring plates to lower ride height.
Re: Ryan's '96
With the new spring plates and deavers ride height only went up a half inch. I still have a slight rake, 3/4" higher in back. Rides sooooo nice.
Re: Ryan's '96
The way I did mine was leave one side bolted up to hold the axels orientation, remove the factory leaf perch. Weld on a replacement at the correct angle. This allows you to shitcan the wedge block and will lower the rear almost an inch. Then repeat on the other side. If you've already done this sorry, I'm at work and don't have time to look through the preceding in the thread. Also you can go +.75-1" easy with the shackle further lowering the rear.
