95 Black Bronco
95 Black Bronco
Picked up a Black 95 the other day, was the cleanest one I found after searching for a couple of weeks. This will be a daily driven prerunner with the intent of going to baja for surf trips and chasing/prerunning score races. Plans are extended beams, 64 kit with notched frame, 2" cage with full interior, trussed 8.8 out of my old lightning, front and rear bumpers, 3 baja design hids, 35" tires on outlaw wheels.
- broncoceach.jpg (19.5 KiB) Viewed 20056 times
- bronco5.jpg (97.85 KiB) Viewed 20056 times
- bronco4.jpg (21.94 KiB) Viewed 20056 times
- bronco3.jpg (108.51 KiB) Viewed 20056 times
- bronco2.jpg (66.43 KiB) Viewed 20056 times
- bronco1.jpg (14.81 KiB) Viewed 20056 times
Re: 95 Black Bronco
more pics of the bumper while I was building it, And I mounted a optima yellow top with a camburg battery tray, the liner is notched around the battery not underneath..
- broncobattery.jpg (23.33 KiB) Viewed 20054 times
- broncobumper1.jpg (26.49 KiB) Viewed 20054 times
- broncobumper2.jpg (22.51 KiB) Viewed 20054 times
- broncobumper3.jpg (25.14 KiB) Viewed 20054 times
- 93Broncobuff
Re: 95 Black Bronco
Sick plan brew! N bitchin bumper!!! Welcome!!!
Re: 95 Black Bronco
I have a feeling good things are to come.
Re: 95 Black Bronco
yup. can't wait to see the build on this. Love your work
Re: 95 Black Bronco
Thanks guys!
Re: 95 Black Bronco
Right on man, stoked to see you building a Bronco!
Re: 95 Black Bronco
Looks good!! Now build me one them rear bumpers!. Please.
Re: 95 Black Bronco
Big fan of your work, looking forward to seeing this come along....
- Kel Fab Creations
- Bronco Info: 95 Bronco
Re: 95 Black Bronco
Nice rear bumper! Looks reeeeeealy similar to mine. One after thought I'm doing to mine is to open up one of the holes next to the receiver so I can slide in the round 7 pin trailer connector keeping it semi flush. For now mines just zip tied to the bottom. Also like how you relocated the license plate.
Looking forward to updates.
Re: 95 Black Bronco
Time to start focusing on the front, started a pair of radius arm mounts tonight, and am picking up a pair of stock beams from a member on here this weekend to truss and extend. Still need to finish the rear overlay and weld washers, the two vertical tabs are for a crossbar/transfer case subframe and skid.
- radarm1.jpg (108.97 KiB) Viewed 19746 times
- radarm2.jpg (16.52 KiB) Viewed 19746 times
- radarm3.jpg (109.45 KiB) Viewed 19746 times
Re: 95 Black Bronco
Not gonna build another set of billet ones like mineC H O wrote:Time to start focusing on the front, started a pair of radius arm mounts tonight, and am picking up a pair of stock beams from a member on here this weekend to truss and extend. Still need to finish the rear overlay and weld washers, the two vertical tabs are for a crossbar/transfer case subframe and skid.
Re: 95 Black Bronco
cs_drums wrote:C H O wrote:Time to start focusing on the front, started a pair of radius arm mounts tonight, and am picking up a pair of stock beams from a member on here this weekend to truss and extend. Still need to finish the rear overlay and weld washers, the two vertical tabs are for a crossbar/transfer case subframe and skid.
definitely not! Lol Im trying to keep everything on this build as simple as possible.
- ESHALLBETTER
Re: 95 Black Bronco
Your lightning was BA. Can't wait to see how the bronco turns out.
Re: 95 Black Bronco
went into the shop today and started on my front bumper among other things. I am running 3 baja design hids.
- bumper1.jpg (110.19 KiB) Viewed 19475 times
- bumper2.jpg (65.48 KiB) Viewed 19475 times
- bumper3.jpg (17.66 KiB) Viewed 19475 times
- bumper4.jpg (87.43 KiB) Viewed 19475 times
- bumper5.jpg (87.24 KiB) Viewed 19475 times
Re: 95 Black Bronco
Also Finished my Radius arm Mts. and started my beams!
- radmt.jpg (31.53 KiB) Viewed 19470 times
- beam1.jpg (27.23 KiB) Viewed 19470 times
Re: 95 Black Bronco
I dig the bumper. Very clean!
- cypher
Re: 95 Black Bronco
You've got serious talent. Those are supermodel welds.
fat dude
- Bronco Info: 99 Ranger XLT, 94 F250 4x4 5.8 comfortable dezert creeper
Re: 95 Black Bronco
Beautiful work man!
Re: 95 Black Bronco
Thanks for the kind words! Decided im going to get these for myself for xmas
- wheel.jpg (37.75 KiB) Viewed 19381 times
