two years and counting
kahuna bill
Bronco Info: auto fab lift, 90 body on 91 frame, e40d, performer heads,jba headers, K&N intake
Post by kahuna bill »
bare bones stock $500 bronco. '91 5.8 electronic transfer case
playing around in pismo.  stock bronco kicked ass next to the jeeps and tacos
first things first.  rebuilt engine, rebuilt trans, added k&n cold air and jba headers
now for the sound system and center console
kahuna bill
Re: two years and counting
time to make it a go fast!  replacing most everything with an autofab kit.  front and rear
yup that's a newb misstake... wrong placement of the straps. moved them to where they belong after being told
cross member hoop support
new 4.56 gears
new 4.56 gears
kahuna bill
new vs old.  sky jacker 4" lift coils
fitting all the parts
painting the radius arms
new springs and old springs.  deavers... um can't remember off hand which ones...
kahuna bill
autofab rear shock mount
had to spread the frame to get bolt holes to line up after drilling out the rivets... still havn't figured out why there was tension in the frame?
new bfg km2 35&quot; x 12.5 x r15  <br />SWEET!
new bfg km2 35" x 12.5 x r15
SWEET!
front set up
front set up
kahuna bill
complete set up. done!
whoops!  wrong placement of the shock mount on the ttb passenger side.  but it was fixed by autofab quickly.
the drag link that rubbed on and bent the passenger shock mount
testing the kit and engine at pismo.
kahuna bill
had to get her off the ground
definitly need to put those second set of shocks up on the front. the shocks were too hot too touch after a couple of mild hours of playing in the sand
last photo of the OJ mobile before she rolled
rolled the truck shortly after this photo was taken. i was romping around knoxville BLM land near napa, ca.
rolled when i came whipping around a cut back too fast and over corrected. luckly we only went to the roof and had two trees stop us before we went all the way down to the bottom. it was a long, cold, wet, and dark hike out back to the main road. and the mt lion i saw along the way didn't help to brighten the mood.
mud, rain and trees suck! i'm sticking to the desert!
kahuna bill
welcome to pope valley towing.
pope valley towing. when i told the owner where i rolled he wasn't at all surprised. he's pulled a lot of people out before. guess i'm not the only idiot who doesn't know how to drive wet mt dirt roads.
back at the scene with tow truck. two cables are connected to the truck and the guy did a damn good job of getting her off the hill side with out additional dammage
kahuna bill
this manzinita tree held the entire weight of the bronco after the tow truck flipped and her and manuvered to a better position. damn strong bush/tree!
just a manzinita tree keeping my truck from going down hill. tow truck manuvering to a better spot
think i need a cage
kahuna bill
it's a much scarier view when ur upside down
trailer and u-haul the truck the full 600 miles back home... now the real work begins. BODY SWAP!
this shell is probably the sole reason why we weren't smashed. only had this crack and a knocked out window. the rest of the shell was unscathed. but the sheet metal was crunched all the way around except for the tail gate.
getting late though, will post more pics later.
Damn! Glad you guys are okay. Time for a cage :)
Wow, what a story! Glad no one got hurt.
So, what are your plans now?
Man, sorry to hear you rolled it, I loved the build.....
Question, instead of a body swap, why not pick up another Bronco and swap your running gear into it? Seems like that might be a simpler solution.
Bummer about the roll! Now you've got us hanging... what happens next!?
kahuna bill
sorry guys... balancing two girl friends (bronco and the real one) takes a lot of time. but yeah, did the swap about 6 months ago. worked real good. i was able to find a $800 donar bronco on craigslist that had the e40d, a 351W, and a manual transfer case. i was stoked. wiring harness was the same and the body was clean with out rust or any major damage.
but to keep with chronology i'll post pics in order.
starting to break the old oj mobile so i can take the scrap to the dump.
will work for beer!
will work for beer!
good friends are hard to find. 24 pack a piece and they're happy to help.
when a plasma torch doesn't get the job done, just grab the BFG and pound away!
I've always been amazed at how strong the rear pillar on the top is. I've seen tons of Broncos wrecked and I don't think I've ever seen that part collapsed.
On a side note it's scary how easy the steel part of the roof will cave in.
kahuna bill
completly naked and waiting for a new dress
BTW, this was a great oppurtunity to access all those hard to reach bolts to make sure everything was tight.
donar bronco
donar bronco
donar bronco. not white, but she'll do for now. $800, with a working engine and aux parts... yeah i'm stoked!
home made lift. for the first time what i did on paper, worked in real life. yeah, more stoke 8-)
more beer for helping hands
kahuna bill
old chasis under new donar bronco
the old go fast chasis, under the new donar bronco.
decided to repaint the grey plastics a dark shadow blue. used the dupli-color paint adhesive with a flexible plastic rattle can paint. worked great, and is still holding to the plastic.
kahuna bill
2010-01-28 11.29.21.jpg (133.53 KiB) Viewed 3063 times
always learning the hard way... went through third crossing at coyote canyon in borrego and got stuck. i needed new pads and cylinders anyways. :?
2010-04-16 10.40.00.jpg (119.54 KiB) Viewed 3063 times
my new rag top :D got it from JBG for almost the same price as the donar bronco :lol:
2010-04-17 12.30.15.jpg (117.72 KiB) Viewed 3063 times
comnplete set up. took a lil longer than other guys from FSB said it took them, but w/e... it's on and keeps the water out.
2010-04-25 14.39.47.jpg (102.82 KiB) Viewed 3063 times
one more goody... time to start making that cage. my next roll might not be as forgiving.
kahuna bill
2010-05-07 13.11.54.jpg (117.34 KiB) Viewed 3060 times
what i've always wanted my garage to look like.
2010-05-08 10.18.31.jpg (109.72 KiB) Viewed 3060 times
before making a cage i figured i'd practice with front and rear bumpers first.
this is the begining of the rear.
2010-05-10 16.02.21.jpg (107.73 KiB) Viewed 3060 times
finsih product... although i think a for and aft brace for the reciever tube should be made?
2010-05-10 16.07.07.jpg (89.96 KiB) Viewed 3060 times
kahuna bill
2010-05-13 11.16.13.jpg (126.53 KiB) Viewed 3057 times
whoops! destroyed my passenger side front wheel bearings... probably from that borrego trip. exploded at 75 mph on the freeway, with a gnarly death wobble that immediatly followed.
2010-05-13 09.04.44.jpg (65.52 KiB) Viewed 3057 times
even friction welded the roller bearings together. :o
2010-05-24 18.59.08.jpg (117.08 KiB) Viewed 3057 times
destroyed the spindle and hub when the bearings blew.
2010-06-02 16.55.44.jpg (121.93 KiB) Viewed 3057 times
new glass, soon to follow up dated front end and hood.
that's where she sits presently.
