Black Lightning
Re: Black Lightning
ESHALLBETTER wrote:There appears to be something large, 4 door, and mezzenined (is that a word?) in the back ground.... I can't make it out through the body work though...please give more details. Also more pics of anything you are working on!
Thats the Suburban.
cypher
Re: Black Lightning
Post by cypher »
Super clean welds... what a great project! Look forward to following this build.
Re: Black Lightning
Thats the Suburban.
yup. There's a build on DR that I can't seem to find right now. Cool stuff for sure.
C H O
Bronco Info: 1993 Lightning
Re: Black Lightning
Post by C H O »
The truck in the background is a 70's 3door suburban I have been working on at Richer Racing. The gist of the suburban is 6 seats. equal length beams, 4link with mezzanine arms, 4.0 king kongs on every corner, everything on this truck is pretty extreme can't wait to see it cruising around with 6 people in it.
Re: Black Lightning
Thing looks good man. I saw it back when you were at giant. Has come along way since then! Get er done.
C H O
Re: Black Lightning
Post by C H O »
cs_drums wrote:Thing looks good man. I saw it back when you were at giant. Has come along way since then! Get er done.
Thanks man! Just read your whole build thread your truck is rad! I remember building your beams, what a pain in the ass! took about two weeks if I remember right.. I might have some old pics of them if you want them
damon1272
Re: Black Lightning
Post by damon1272 »
Very nice build. I really like how you did the A pillar/dash bar. Really simplifies things. Think I will use this for when I do my cage. Keep the pictures coming.
C H O
Re: Black Lightning
Post by C H O »
Thanks doing the dash that way makes it alot easier to drop down when everything fits tight and you have tubes stubbed out the back, just be sure to cap the open ends with whatever thickness tubing you are using
Re: Black Lightning
Haha I remember Geoff saying to tell everyone they cost $10k so no one would ask you guys to build another set. I would love the pics. Ill PM you my email address.
C H O
Re: Black Lightning
Post by C H O »
got the rear end mocked up and cyclying, in the process of desgning the backhalf now. Expect some big updates soon!
Re: Black Lightning
Liking the progress, what rear end is that? Specs?
Re: Black Lightning
Pics of that white Bronco!!
C H O
Re: Black Lightning
Post by C H O »
cs_drums wrote:Liking the progress, what rear end is that? Specs?
it is a blitkrieg housing 3.5 tubes full 4130 tig welded, really nice part!
Ill get some some pics of the white bronco or maybe have the owner start a thread, its a awesome truck, i have been working on it for the past couple months. Has everything you could want minus links.
C H O
Re: Black Lightning
Post by C H O »
Here are some more pics, I drew up the back half the other day, real excited to get going on it. front has 13" of up travel, will probably bump it lower for ground clearance reasons. The rear has 14" of uptravel at ride height, the truck sits 4-5" taller than stock with 37" tires
C H O
Re: Black Lightning
Post by C H O »
more
Re: Black Lightning
Drool.... Love the wheels too btw.
Re: Black Lightning
That one long continuous bead I think on the side of the frame is absolutely beautiful. Do you worry about serious warping with a weld that long and nonstop. If it's not continuous the transitions are literally perfect.
C H O
Re: Black Lightning
Post by C H O »
VintageIronFab wrote:That one long continuous bead I think on the side of the frame is absolutely beautiful. Do you worry about serious warping with a weld that long and nonstop. If it's not continuous the transitions are literally perfect.
Thanks, no worries about warping, there is enough structure to keep things from moving. And yes, i try to do as little starts and stops as possible.
Re: Black Lightning
any progress pics to share?
C H O
Re: Black Lightning
Post by C H O »
Finally got to start on the back half last week, 2 days in a and ran out of material and our supplier had to order more so hopefully more updates next week
