Has anyone run Raptor FOX's on their BRONCO?
Mojo
I am currently installing Raptor rear FOX internal bypass shox on the rear of my 96 Bronco to a Southwest shock mount. Also does anyone know how many bypass zones they have?
- 's.jpg (33.03 KiB) Viewed 3321 times
Re: Has anyone run Raptor FOX's on their BRONCO?
If I remember correctly I think it was three but I am not totally sure as the last time I had one open was a couple of years ago.
Mojo
Thanks Brandon, hopefully it is three.
This is a cool idea. Let us know how it works out.
Are the shocks serviceable? Seems like the valving would be a mile off.
Mojo
Yes Travis they are serviceable as far as I can tell, but I was hoping to run them for 1 season before I open them up. We're talking about a family "fun-runner" for Ocotillo Wells so I'm not that critical.
They are but ive heard they're expensive to mess with.
I do not think the valving will be too far off for a family runner. The shocks are fully serviceable.
Does shockseals offer a kit for these yet?
damon1272 wrote:I do not think the valving will be too far off for a family runner. The shocks are fully serviceable.
Seems like they would be way too soft. I'm sure they are going to be better that a Pro Comp or something similar though.
Mojo
I haven't contacted Shockseals yet so I don't know about kits, which I'm not ready for anyway. I am going to Ocotillo the 24th & I still need to rebuild my front Fox 2.0 resi's that I have Shockseals sitting on the workbench. I did get 1 of the raptor 2.5's on last nite in the dark!!!
- BrncShox.JPG (80.98 KiB) Viewed 3152 times
Mojo
[/quote]
Seems like they would be way too soft. I'm sure they are going to be better that a Pro Comp or something similar though.[/quote]
Speaking of ProComps, that's what I had on the rear for the last year & was very pleased. But I did go from stock to F53's, the long Solo shackle kit & used procomps. I know these 2.5's will be another huge upgrade even if not valved perfect right now.
Seems like they would be way too soft. I'm sure they are going to be better that a Pro Comp or something similar though.[/quote]Mojo's96 wrote:
Speaking of ProComps, that's what I had on the rear for the last year & was very pleased. But I did go from stock to F53's, the long Solo shackle kit & used procomps. I know these 2.5's will be another huge upgrade even if not valved perfect right now.[/quote]
I must drive my truck a lot differently then you. I destroyed a brand new set of Pro Comps in one weekend!
Mojo
Yeah Travis you probably do. I always have my wife & my 4 & 6 year old kids with me & run around Ocotillo & Borrego for the most part. I think I run pretty hard considering, But then again I've got the A/C goin & the tunes crankin
Mojo
So after having to move the muffler forward about 4"s I got the other shock on this weekend. And guess what Travis, the rebound "valving is way too soft"
The compression valving feels ok though. So now I 'm gonna pull them apart & re-valve the rebound.
Do these only bypass on compression? Does rebound flow strictly through the piston?
Mojo
I can't answer that, yet!!!
Top out and last bit of travel are piston only in both directions.SteveG wrote:Do these only bypass on compression? Does rebound flow strictly through the piston?
- Phoenix0783
There was a Bronco at the short course races in redmond that had Raptor shocks and the front pogo'd like a mofo. Back seemed decent.
Ford 4 US
- Bronco Info: 96 and 79 (79 is a basket case right now)
Not to derail this topic... But I had the same idea of putting some Raptor take offs on my ride...
In the rear.. Going broke working my way back there........
Anyhow.. shockseals I am going to be close to Sandiamis in a few weeks can I drop off some Fox coilovers for u to go thru ???
Thx...
Thx...
