Bronco and 9,000 to spend
Re: Bronco and 9,000 to spend
Looks badass Drew!!
Who did the bumper?
Drew
Bronco Info: Just picked up a 95 bronco stock. Ready to make it go fast....lol
Post by Drew »
A buddy of mine in Hemet owns a fab shop Total fabrication. He's good and charges a fair price.
Drew wrote:A buddy of mine in Hemet owns a fab shop Total fabrication. He's good and charges a fair price.
Your Bronco, does look Good !.
Is that a 12" coilover with a 14" bypass? What setup will you run in the rear?
Drew
Post by Drew »
In the front yes. The rear I did Q80's with a 12inch bypass
Drew
Post by Drew »
Thanks Andy
Drew
Post by Drew »
PRP seats on the way. Inner fenders Monday start on the Rollcage and back bumper. Exhaust almost done.
Drew
Post by Drew »
Drew
Post by Drew »
Drew
Post by Drew »
Bumper done. Roll cage or inner fenders next.
Kel Fab Creations
Bronco Info: 95 Bronco
Post by Kel Fab Creations »
I really like that southwest front setup! Is all the work getting done at total fab?
Drew
Post by Drew »
Ya almost done.
Drew wrote:
Bumper looks good, is it rectangular tube or c-channel?
Drew
Post by Drew »
Tube
Drew
Post by Drew »
Just found out the damn rear end tube is bent. I have a body shop that says we can stick it on a frame machine and tweak it. Hope that will work!!! :|
Remove everything to bare housing, find a straight unbent piece of tubing the same o.d. as the I.d. of the housing flanges. Try to pass it through flange to flange. If it won't go it's bent, depending on how bad you can heat the bent area with a rose bud oxy aceteline tip then quench the cherried area to have the housing shrink toward the quickly cooled direction. Repeat the process until its straight enough to pass a bar through. If its really bad a big ass press is the only way. Good luck hope it helps.
Drew
Post by Drew »
Thanks going to get if finished then deal with that issue. Was going to have a buddy with a farme machine look at it. But will try your method. I have an induction heater that would work great for that.
Any updates Drew?
Drew
Post by Drew »
Drew
Post by Drew »
