95 f150 4x4
Re: 95 f150 4x4
Looks great! Is that a drop center hood? Or just the light?
Re: 95 f150 4x4
I thought the same thing, but I think it is the light
Re: 95 f150 4x4
I still want a drop center hood, they make the front flares look trophy truck/rc car-ish, it just gives it the look of the tires having a place to go at full tuck. Amazing what a little paint can do huh? Slick truck for sure.
- steve-oh
- Bronco Info: 93 xlt,5.0 caged, extended beams work in progress
Re: 95 f150 4x4
Yea its a factory hood, going to do fiberglass later on, trying to keep down time to a minimum, no fun just building and not using
- Silverslk
Re: 95 f150 4x4
Damn.,... That thing looks GOOD!!
Re: 95 f150 4x4
Love the color!
Re: 95 f150 4x4
I don't know, I kinda liked the red white and blue. It was very patriotic........
- steve-oh
Re: 95 f150 4x4
Thanks for the compliments, amp is installed, got some tunes again and started on front bumper , be ridin soon
- steve-oh
Re: 95 f150 4x4
Color is electric red, the original color of the truck
- steve-oh
Re: 95 f150 4x4
Got the 1st stage of the front bumper finished,time to drive it and see the bugs that creep out.....
- phpWSOpbYPM.jpg (57.34 KiB) Viewed 2027 times
- phpKkiexnPM.jpg (55.57 KiB) Viewed 2027 times
- Kel Fab Creations
- Bronco Info: 95 Bronco
Re: 95 f150 4x4
Color looks nice!
- steve-oh
Re: 95 f150 4x4
Thanks......problem number one, some how front tank has a pinhole some where, new tank or fuel cell? Next issue gear oil is pouring out of ds axle seal, did feel alittle stiff going in though.
Re: 95 f150 4x4
Parts geek.com has the seals.
Re: 95 f150 4x4
The rust hole is probably on top next to the strap. My F250 has one there. I just don't fill the front tank all the way................
- steve-oh
Re: 95 f150 4x4
Yea the leak was right on the front strap but on the lower side, just got a replacement tank for now fuel cell would be to much of a pain right now
- phps6hmItAM.jpg (37.04 KiB) Viewed 1988 times
Re: 95 f150 4x4
Oh I thought u ment the front axel seals were leaking, my bad.
- steve-oh
Re: 95 f150 4x4
,No one of those are leaking too, the only seals i didnt replace....drove around today, nice to ge back in my truck again
......i can see the potential for trouble on this build!
- steve-oh
Re: 95 f150 4x4
Been driving the truck for a few days, truck seems to wander just a bit, going to tighten up the box a little and see if that helps, have a little play in the box and maybe adjust the camber a little more.....
Re: 95 f150 4x4
Check the tow in also.
- steve-oh
Re: 95 f150 4x4
,Yea i put it on the machine and adjusted the cams but should of probably went a little futher with the camber, i think its more on the postive side should of put it at zero to start with, but toe was adjusted after the camber was.....
