Thanks for the info travis.Travisfab wrote:
You will want to cut out the area in the yellow box. That flange is only needed if you are deleting your radiator core support.
95 f150 4x4
- steve-oh
- Bronco Info: 93 xlt,5.0 caged, extended beams work in progress
Re: 95 f150 4x4
- steve-oh
Re: 95 f150 4x4
Thats my plan, cut the brace from the inside of the wheel well to bed side, put a jack in the push it out as far as i can w/o wrinkling the side, going to practice with the bed thats on there.....thanks for the guidance guys keep it comingRmc wrote:Not to get too ghetto fabulous on you but quite a few local kids cut the spot welds then press the bed sides out with a 2x4, hold em in place with the 2x4( between frame and inside of bed skin. Then take 1 inch conduit smash the ends flat. Bend it over 90, hold it to the frame mark the other side ( flat) then bend that side to 90 also. Kinda like a cheap brace in the shape of a Z. I'm not saying I would rock it but if buget is super tight 7 to 10 bucks for 3 or 4 tries is ready for race day. It Beats shredded tires anyday. Proving where there's a will theres a way.
- steve-oh
Re: 95 f150 4x4
The steering linkage interchanges between 2 & 4 wheel drive if i remember correctly Right?
- steve-oh
Re: 95 f150 4x4
Dropped off for paint today should be done sunday
- phprY5a7lAM.jpg (45.19 KiB) Viewed 2168 times
Re: 95 f150 4x4
Nice. This thing is progressing quickly!
Re: 95 f150 4x4
Can't wait to see after paint.
- steve-oh
Re: 95 f150 4x4
Trying to be driving this thing by next weekend,...still have to swap in front end and fix the a/c, steering linkage should interchange right
- steve-oh
Re: 95 f150 4x4
Rebuilding front axle today, ball joints, bearings, seals and brakes
- phpl4VMZoAM.jpg (39.13 KiB) Viewed 2133 times
- steve-oh
Re: 95 f150 4x4
Sand, sand,sand......
- phpt6FAIDAM.jpg (43.12 KiB) Viewed 2102 times
- phpMRQN3RAM.jpg (41.08 KiB) Viewed 2102 times
Re: 95 f150 4x4
Nice work........
Pop the chrome trim around the windshield off.....it just has little clips on it, will help for a better paint job.
- steve-oh
Re: 95 f150 4x4
Little sneak peak.....just got it back to shop at home, put it all back together tomorrow and put the front beams in
- phpNPTu11PM.jpg (34.38 KiB) Viewed 2083 times
- steve-oh
Re: 95 f150 4x4
Picked up some goodies for another project too while i was out......
- phpMSC0BaPM.jpg (45.17 KiB) Viewed 2083 times
- steve-oh
Re: 95 f150 4x4
Any chance i could get some dxf cut files for some rear spring hangers and shackles for my laser guy
- steve-oh
Re: 95 f150 4x4
Had a set back, wrong ratio in rear end from the frame donor truck, so went ahead and put a e 150 8.8 rear end in, gained 1.5 inches gonna be close with the pulled bedsides
- steve-oh
Re: 95 f150 4x4
Probably going to break done and get my own bender too, so thats going to put things behind, but its been long over due. Looking at the model 32 now, was using a friends model 4 and it was sweet but alittle pricey.
- steve-oh
Re: 95 f150 4x4
Almost back together....got to build a temporary ft bumper till i get my bender, install my amp, fix ac and we are rolln.
- php3bHEb4PM.jpg (58.12 KiB) Viewed 2024 times
- php8v6j7BPM.jpg (49.53 KiB) Viewed 2024 times
- phpBuOccxPM.jpg (56.69 KiB) Viewed 2024 times
- FUFIMI
- Bronco Info: 1965 Ford F100 (Señor Mostaza)
Re: 95 f150 4x4
Look really good
- ESHALLBETTER
Re: 95 f150 4x4
Damn, that thing looks gay
- ESHALLBETTER
Re: 95 f150 4x4
Sorry! I'm on my phone! That looks GREAT!
