I agree with travis. Microwave transformers can be bought on eBay for cheap, already removed.
as far as deleted that could be debated both ways. this kind of modification is already all over the internet.
Yes this will be a tire groover. I want to be able to take out large chunks and I don't want to pay $400 for a good unit. Technically you can build this for free, but I'm going to buy a couple parts.
Also what I'm doing is not new, lots of people use power transformers for lots of things, you can even make a welder with them. I think I'm just the first person to make a write up on how to make one for a tire groover.
back to the project; you need to remove the secondary winding, if you look closely you can see there's red wire winding in the center, remove that too.
I used a cut off wheel to cut 1 side then punch the wire through. Supposedly you can also grind the welds off the housing and a side will come off, then you can slide the winding off. Either way it will take a few minutes of work.
you want it to look like this, be sure you don't damage the primary winding. After this, I'm going to the store to buy some 4 or 6 gauge insulated wire. Technically jumper cables would work for this next step too.
