We're using a camburg l/t race kit for the front. We got a killer deal on it and it turns out that it was the first one that they ever made. The back will be 4-linked with a kit from a guy here in Oregon. We'll be using a Solo cage. We're switching out the 5r55e for a 5r55s, which means we have to yank the entire wiring harness and use one out of a 2002 to 2004 explorer that had that transmission. We have a setup to replace the steering rack with a swing set system since they have a tendency to break often from abuse.
Starting point:
![Image](http://i.imgur.com/rvqe8.jpg)
![Image](http://i.imgur.com/jxGm6.jpg)
![Image](http://i.imgur.com/UJcg7.jpg)
![Image](http://i.imgur.com/xmpV0.jpg)
![Image](http://i.imgur.com/sUYoK.jpg)
![Image](http://i.imgur.com/ZZDkd.jpg)
![Image](http://i.imgur.com/OYfcb.jpg)
Began making progress fairly quickly:
![Image](http://i.imgur.com/8irS9.jpg)
![Image](http://i.imgur.com/I5f88.jpg)
Shocks. 10" in front and 14" in rear
![Image](http://i.imgur.com/pIF80t2.jpg)
![Image](http://i.imgur.com/mqkN1Eh.jpg)
Wasn't looking for this at the time but found one for an awesome deal
![Image](http://i.imgur.com/Sd1BPHv.jpg)
Cab off:
![Image](http://i.imgur.com/J7GuTUV.jpg)
Started working on engine placement. Ended up with 13" of setback and 3" of drop
![Image](http://i.imgur.com/M249VQG.jpg)
![Image](http://i.imgur.com/0PFs0Bm.jpg)
Roll cage:
![Image](http://i.imgur.com/diUvMQY.jpg)
These link mounts cap the frame and start the back half
![Image](http://i.imgur.com/Iu6f6iZ.jpg)
![Image](http://i.imgur.com/NwSxwTR.jpg)
From when the rear end showed up. So wide they needed an extra box! 35 spline chromoly axles:
![Image](http://i.imgur.com/7oMDqmw.jpg)
![Image](http://i.imgur.com/Uqn48BI.jpg)
![Image](http://i.imgur.com/zI9FnNl.jpg)
![Image](http://i.imgur.com/Gy8hbNB.jpg)
![Image](http://i.imgur.com/tTSQGlU.jpg)
![Image](http://i.imgur.com/VJsQDpj.jpg)
![Image](http://i.imgur.com/jmiyf95.jpg)
![Image](http://i.imgur.com/F0l1qX3.jpg)
Getting the frame caps put on:
![Image](http://i.imgur.com/9d3vIzh.jpg)
![Image](http://i.imgur.com/gOIJRcE.jpg)
![Image](http://i.imgur.com/bgX4m3V.jpg)
![Image](http://i.imgur.com/vEpfd17.jpg)
![Image](http://i.imgur.com/inyctQX.jpg)
![Image](http://i.imgur.com/XYyvHPc.jpg)
Put the cab back on the frame and started on the cage today:
![Image](http://i.imgur.com/ARPwKcI.jpg)
![Image](http://i.imgur.com/mcZxUOG.jpg)
![Image](http://i.imgur.com/PKLg91g.jpg)
