- bajascott
- My belly is my best friend
i think you should make a removable mount for those badass lights,and call it done.
i like the simplicity of it now. low profile and not overwelming.
- Silverslk
What do you mean? No Skid plate? Just removable light bar?bajascott wrote:i think you should make a removable mount for those badass lights,and call it done.
They are working on a custom way to mount the light bar without bulky "pins" sticking up to slide on to........I am anxious to see what they design.
As for skid, I like clean and simple. I have been watching tons of off road videos to see what I like and what I don't. I will make multiple cardboard versions until I am satisfied, then make an aluminum skid once.
- bajascott
yea sorry, skid plate is needed! haha
i just mean i like the simple design with out the hoop over lights, i was assuming you were doing that.
it looks good,i like your bronco.
just run vertical boss' through the main tube and light bar and bolt through them. If you want to get tricky machine custom boss' so the light bar boss "engages" or fits into the main tube boss slightly.
Mounting like this will be stout and they pretty much "disappear" when the light bar isn't on the truck.
If you want a drawing of what I mean let me know.
*edit* - semi bored at work so I drew up something quickly.
Left side is straight boss on boss. Right side is another idea to get a firmer "connection" between the light bar and bumper. It's just a piece of tube (2.5" dia. - so might not be lying around the shop) halved and set on top of the 2" main tube.
Of course this all depends on how your light bar mount is designed - but it's an idea and it gave me something to fart around with for 5 minutes
WTF - thing wouldn't load my attachment so trying again...
ok - F this.
Email me if you want it.
I made a PDF from cad. Can't upload a pdf. Therefore I saved to jpeg format. For some reason file size is staying "big" (625mb) even after I re-sized it and it won't let me load that.
If you wanna see the thing PM or email me and I can email it to you.
ok - F this.
I wanna see your thing??!!
- bajascott
/\ /\ uh....this is not the place for that tony.......
If you email it to the site email (gofastbroncos@gmail.com), I can host it on that gmail account and post the link.ChaseTruck754 wrote:WTF - thing wouldn't load my attachment so trying again...
ok - F this.
Not sure why I had issues with getting it posted yesterday but I got frustrated and said F it.
Andy did email me and I sent to him, but since Tony likes looking at my thing too - I'll send it along so everyone can see. I'm a sharing type person like that ya know!
The image uploaded OK for me.
- light bar mount on bumper.jpg (587.37 KiB) Viewed 2068 times
yeah - but you have "special" powers
It said something like 325kb was the max file size. It was 635kb before I re-sized it and I think something like 585 after, so it wouldn't load.
- Silverslk
I only see a red X
X2.Silverslk wrote:I only see a red X
I just checked it with Internet Explorer and I get an X too... add that to the LOOOOOOOOONNNNNNNNNNG list of reasons I don't use Internet Explorer.
I can't log in when i use firefox.SteveG wrote:I just checked it with Internet Explorer and I get an X too... add that to the LOOOOOOOOONNNNNNNNNNG list of reasons I don't use Internet Explorer.
you aren't missing much Nick - trust me. Andy has seen it already since I emailed it to him and I'm sure he can vouch that it's nothing special
- Silverslk
Yep, seen it. Since I'm not the fabricator type I have a couple questions. Would you drill a hold through and then weld a sleeve in there for support then just bolt through that sleeve to the removable bar (depending on shape)?
I demand to see this so called picture you are all talking about..!!!
Tony - email me if you want me to send it to you after you see the below.
I ran across this pic yesterday and save the address so I could post here. It shows what I am talking about pretty much. And yes Andy - I personally would run a boss through the hole in the tube rather than just a bolt through it. Makes it stronger.
*edit* Damn this thing again!
Tried to insert as an image and then as a link - but won't work because it's hosted on dezertrangers so it asks you to sign in.
Tried attaching and it says no files over 300kb. Trying again....
ok - got it. Sorry for the huge size. I had it a 4x6 but didn't look at pixel size. You can see the boss' I was talking about. I wouldn't make them stick through the main tube as far as these guys do (I keep mine pretty much flush) but you get the idea.
- bronco bumper.jpg (272.09 KiB) Viewed 1966 times
- Silverslk
So, a late update but update none the less.
I wanted to run my lights for the night race last weekend. I called Pirate Lab in Corona and they agreed to get it done for me on Friday (they actually pulled off another job to get me done on short notice). After talking it over with them (and Steve and a few others) I went with the mounting system like above. Pirate lab will rush for you but they don't cut corners (still capped ends and actually machined the sleeves on their lathe). Here's how it came out.
- IMG_0351.JPG (80.23 KiB) Viewed 1905 times
- IMG_0348.JPG (84.85 KiB) Viewed 1905 times
- IMG_0350.JPG (77.31 KiB) Viewed 1905 times
