BACK IN THE DIRT
Well? Who are you?
78 DESERT RAT
Bronco Info: 78 Ford Bronco
BACK IN THE DIRT
Post by 78 DESERT RAT »
Brought my Bronco out of the garage this past weekend after a couple of years of hibernation. Its a 78 straight axle with a fabricated 9" housing straped at 12" sway away 2.5 on all corners, heimed steering and full cage front to back.
Re: BACK IN THE DIRT
AWESOME bronco! More pics & info on it please.
Oh and welcome!
Thats awesome!!!
I love that body style. Welcome!
Sweet! Welcome to the club!
78 DESERT RAT
The rear end is 1.5" wider than stock has a detroit locker and Dutchman axles. Deaver spring pack 3" wide, Wilwood brakes. Motor, trans, and transfer case all stock. Front end stock but with heim steering and swayaway shocks. Replaced front lock out hubs with drive flanges after breaking a hub once down in Mexico. Front brakes stock, Deaver coil springs in front. 4.56 gearing front and rear.
sounds like a cool setup - thanks
Dust
Post by Dust »
Sweet truck.
Have a 78 in the shop that is headed that direction.
Dust
Kel Fab Creations
Bronco Info: 95 Bronco
Post by Kel Fab Creations »
Very nice! Welcome.
Kelly @ Kel Fab Creations
Wat a gorgeous Bronco! More pics plz!!! Oh, and welcome.
Welcome and love it!
78 DESERT RAT
Thanks for welcoming me to the site guys. I will get more pictures posted as soon as I can.
300
Post by 300 »
Very cool and very clean truck! I would also like to hear how the heim steering change went and if the bump steer changed at all.
78 DESERT RAT
The heim steering was one of the best changes I made to the Bronco from stock. I experience no bump steer that I can tell, and I drive the vehicle at a pretty good pace through the desert. The track bar and drag link are almost parrallel with the heim steering. All of the components are much lighter than the stock parts, well worth the investment.
Don - do you have stock type steering on the race truck???
300
Post by 300 »
Yes, still all stock stuff and geometry. I have done some mock up with heims, cycling it in the shop, and couldn't prove to myself that I could at least match the stock bump steer. Have not spent enough time with it and come up with the right geometry yet when the stock geometry has been acceptable.
Got it. I figured you might go through tie rods pretty good with all those dirt/race miles on the truck, but it's a testament to factory geometry if you haven't!
300
Post by 300 »
Haha, I didn't say anything about how LONG the stock stuff lasted! I have them piled up like cord wood around the place. The stock tie rod ends will go about 50 miles before they get sloppy again, and they are pretty well shot by 800 miles. Maybe I can build a log cabin with them?
78 DESERT RAT
Thats why I changed mine, could not make them last more than 500 off road miles.
Ok now that makes more sense.
Is there something in the way of replicating the factory design/specs but with tube & heims on the ends? There's got to be a reason it's not that easy though or I suspect you would have done this already. What seemed to get in the way when you messed with it?
